Datasheet TCKE6 (Toshiba)
ManufacturerToshiba
Description40 V, 2.5 A eFuse IC with Adjustable Overcurrent Protection in TSOP6F package
Pages / Page26 / 1 — TCKE6 Series. Description. Features. Notice
Datasheet TCKE6 Toshiba
TCKE6 Series Toshiba CMOS Linear Integrated Circuit Silicon Monolithic
TCKE6 Series
TCKE6xx series are Single Input-Single Output eFuse ICs with maximum operating voltage of 30V. It can be used as a reusable fuse, and includes protection features like adjustable over current limit by an external resistor, short circuit protection, under voltage protection, and thermal shutdown. Switch ON resistance is only 52 mΩ (typ.), and the output current TSOP6F is up to 2.5 A and wide input voltage operation characteristics make this series ideal for 24 V power management. Weight: 15 mg (typ.) This series is available in small package TSOP6F (2.9 mm x 2.8mm (typ.) and t: 0.8 mm (typ.)). Thus, this series is ideal for various applications such as industrial equipment and home appliances, etc.
Features
● Maximum input voltage: VIN (max) = 40 V ● Input voltage range: 4.4 V to 30 V ● Low ON resistance: RON = 52 mΩ (typ.) ● Adjustable overcurrent protection: 0.35 A to 2.4 A (Overcurrent limit) ● Slew rate control ● Thermal shutdown ● FLAG function: TCKE601 ● MODE (Selectable recovery mode): TCKE602 ● Enable function: TCKE603 ● Output discharge ● Small package: TSOP6F (2.9 mm x 2.8 mm (typ.), t: 0.8 mm (typ.))
Notice
This series is sensitive to electrostatic discharge. Please ensure the equipment and tools are adequately earthed when handling. Start of commercial production 2025-09 © 2 025 1 2025-10-28 Toshiba Electronic Devices & Sto ra ge Cor pora tion Rev. 4.0
