User Manual WIZ-IP55 (WIZnet) - 5
ManufacturerWIZnet
DescriptionCompact Ethernet network offload module based on W5500, a hardwired TCP/IP chip that integrates the TCP/IP stack plus 10/100 Ethernet MAC & PHY
Pages / Page11 / 5 — WIZ-IP55 User Manual. 1.1.2 Product features. 1.2 Product Specifications. …
File Format / SizePDF / 745 Kb
WIZ-IP55 User Manual. 1.1.2 Product features. 1.2 Product Specifications. 1.2.1 Electrical Parameters
WIZ-IP55 User Manual 1.1.2 Product features 1.2 Product Specifications 1.2.1 Electrical Parameters
 All-hardware TCP/IP protocol stack network chip W5500  Ethernet 10/100Mbps Adaptive Ethernet  Connect to the host interface Standard SPI: MISO, MOSI, CLK, CSn  Power supply Input power supply: 3.3V DC  Mechanical parameters Dimensions(length×width×height):32.5×16.5×17.3(mm)  Working temperature Industrial grade:-40 ~ +85℃  Save Environment -40 ~ +85 ℃,5 ~ 95% RH
1.2 Product Specifications 1.2.1 Electrical Parameters 1.2.1.1 Power Supply Parameters
Unless otherwise specified,the parameters listed in Table 1-1 and Table 1-2 refer to the values at a temperature of 25℃. Table 1-1 Power Parameters
Specification Numbering Category Min Typical Max Organization
VDD Module voltage 2.97 3.3 3.63 V I Module current 152 162 173 mA
1.2.1.2 Power Consumption Parameters
Table 1-2 Power consumption parameters
Test value Test value Working condition Working condition
mA
mA
) Standby 65 100 Mbps without connection 128 10 Mbps without connection 75 100Mbps for data communication 162 10 Mbps for data communication 79
WIZ-IP55 User Manual 4 / 10
