Datasheet SSD13XX (Solomon Systech) - 2
ManufacturerSolomon Systech
Description128 x 64, Dot Matrix OLED/PLED Segment/Common Driver with Controller
Pages / Page4 / 2 — ADVANCED DISPLAY. OLED Driver Controller. Application Diagram. Selection …
ADVANCED DISPLAY. OLED Driver Controller. Application Diagram. Selection Guide - Mono/Area Color. Dot Matrix Panel
ADVANCED DISPLAY OLED Driver Controller Application Diagram Selection Guide - Mono/Area Color Dot Matrix Panel
ADVANCED DISPLAY ADVANCED DISPLAY OLED Driver Controller OLED Driver Controller Application Diagram Selection Guide - Mono/Area Color Dot Matrix Panel 256 Icon Mode Connections Part Number SSD1305 SSD1306 SSD1307 SSD1308 SSD1309 SSD1311 SSD1313 SSD1316 SSD1360 Display Features
Maximum panel resolution 132 x 64 128 x 64 128 x 39 128 x 64 128 x 64 20 Char x 4 Lines 128 / 256 128 x 39 120 x 17 + Icon Lines 32 icons Embedded SRAM display buffer 132 x 64 bits 128 x 64 bits 128 x 39 bits 128 x 64 bits 128 x 64 bits 80 x 8 bits − 128 x 39 bits 120 x 16 bits
OLED Display Panel
Mono and 4 color Display color selections for area color Mono Mono Mono Mono Mono Mono Mono Mono Contrast control 256 steps 256 steps 256 steps 256 steps 256 steps 256 steps 256 steps 256 steps 256 steps
DC Characteristics
Segment/Common Outputs Segment maximum source current 320uA 240uA 320uA 150uA 320uA 450uA 320uA 160uA 600uA Common maximum sink current 45mA 30mA 40mA 20mA 40mA 45mA 40mA 20mA 80mA
MCU OLED Driver IC
2.4V - 3.6V / 2.4V - 3.6V / ICS0 CS1 CS2 ICS125 ICS126 ICS127 MCU interface Voltage Supply (VDDIO) 1.6V - VDD − − − − 4.4V - 5.5V − − 4.4V - 5.5V
ICCA1 ICCB1
2.4V - VDDIO / 1.65V - 3.3V 2.4V - VDDIO / Core V
OLED Icon Driver IC
DD power supply (VDD) 2.4V - 3.5V 1.65V - 3.3V 1.65V - 3.3V 1.65V - 3.3V 1.65V - 3.3V 1.65V - 3.3V internally regulated internally regulated
ICCA0 ICCB0
High Voltage Supply (VCC) 7.0V - 15.0V 7.0V - 15.0V 7.0V - 15.0V 7.0V - 15.0V 7.0V - 16.0V 8.0V - 15.0V 7.0V - 16.0V 7.0V - 15.0V 8.0V - 15.0V
MCU Host Interface Supported
4-bit parallel interface − − − − − − − VSS VDD VCC 8-bit parallel interface
MCU
Serial peripheral interface VSS VDD VCC I2C interface
Package Information
TAB T7(132x64) − − U(128x64) − − − − − COG Z(132x64), Z3(132x64) BZ(128x64) Z2(128x39) Z2(128x64) Z(128x64) M1Z8(100x32) Z(128x4) Z(128x39) Z(120x17)
High Integration Controller Function Dot Matrix Panel With Icon Display Connections
On-chip oscillator Programmable frame rate ICON Programmable display MUX − Segment/ Row/Column re-mapping − Common Horizontal scrolling − Outputs Vertical scrolling by RAM − Content scrolling − − − − − − Internal charge pump regulator − − − − − − − Internal IREF selection − − − − − − − On-chip Character ROM − − − − − − − Graphic mode − − − − − − − −
Selection Guide - Gray Scale
VCC
Part Number SSD1322 SSD1326 SSD1327 SSD1329 Display Features
Maximum panel resolution 480 x 128 256 x 32 128 x 128 128 x 128, 64 hard icons Dot Matrix Embedded SRAM display buffer 480 x 128 x 4 bits 256 x 32 x 4 bits 128 x 128 x 4 bits 128 x 128 x 4 bits Segment/ Display color 16 gray scale 16 gray scale 16 gray scale 16 gray scale V Common DD Contrast control 256 steps 256 steps 256 steps 256 steps Outputs
DC Characteristics
Segment maximum source current 300uA 100uA 300uA 350uA Common maximum sink current 80mA 25mA 40mA 40mA MCU interface Voltage Supply (VDDIO) 1.65V - VCI 1.7V - VDD − 1.7V - VDD VSS
OLED Driver IC
Core VDD power supply (VDD) 2.4V - 2.6V 2.4V - 3.5V 1.65V - 2.6V 2.4V - 3.5V Logic Voltage Supply (VCI) 2.4V - 3.5V − 1.65V - 3.5V 3.2V - 4.2V (for icon)
OLED Display Panel
High Voltage Supply (VCC) 10.0V - 20.0V 9.0V - 15.0V 8.0V - 18.0V 9.0V - 18.0V
8-bit parallel interface Serial peripheral interface I2C interface − −
Package Information
COF (256x64) − − − ICON COG − Z(256x32) ZB(128x128) Z(128x128, 64 icon) Segment/
MCU High Integration Controller Function
Common On-chip oscillator Outputs On-chip DC-DC booster − − − for hard icon On chip VDD regulator − − Programmable frame rate Programmable display MUX Row/Column re-mapping Horizontal scrolling − Vertical scrolling by RAM Graphic acceleration command set: e.g. draw rectangle & copy − − −
