Datasheet MP2315 (Monolithic Power Systems)
ManufacturerMonolithic Power Systems
DescriptionHigh Efficiency 3A, 24V, 500kHz, with AAM (light load mode), Synchronous Step Down Converter in TSOT23-8 package
Pages / Page18 / 1 — MP2315. High Efficiency 3A, 24V, 500kHz. Synchronous. Step Down …
MP2315. High Efficiency 3A, 24V, 500kHz. Synchronous. Step Down Converter. The Future of Analog IC Technology. DESCRIPTION
Datasheet MP2315 Monolithic Power Systems
MP2315 High Efficiency 3A, 24V, 500kHz Synchronous Step Down Converter The Future of Analog IC Technology DESCRIPTION FEATURES
The MP2315 is a high frequency synchronous Wide 4.5V to 24V Operating Input Range rectified step-down switch mode converter with 3A Load Current built in internal power MOSFETs. It offers a 90mΩ/40mΩ Low Rds(on) Internal Power very compact solution to achieve 3A continuous MOSFETs output current over a wide input supply range Low Quiescent Current with excellent load and line regulation. The High Efficiency Synchronous Mode MP2315 has synchronous mode operation for Operation higher efficiency over output current load range. Fixed 500kHz Switching Frequency Current mode operation provides fast transient Frequency Sync from 200kHz to 2MHz response and eases loop stabilization. External Clock Full protection features include OCP and AAM Power Save Mode thermal shut down. Internal Soft Start OCP Protection and Hiccup The MP2315 requires a minimum number of Thermal Shutdown readily available standard external components Output Adjustable from 0.8V and is available in a space saving 8-pin Available in an 8-pin TSOT-23 package TSOT23 package.
Notebook Systems and I/O Power Digital Set Top Boxes MP2393 Flat Panel Television and Monitors All MPS parts are lead-free and adhere to the RoHS directive. For MPS green status, please visit MPS website under Products, Quality Assurance page. O “MPS” and “The Future of Analog IC Technology” are registered trademarks of Monolithic Power Systems, Inc.
TYPICAL APPLICATION
RECOMMENDED FOR NEW DESIGNS 100 95 90 NOT 85 80 REFER T 7570 65 60 0.01 0.1 1 10 MP2315 Rev. 1.01 www.MonolithicPower.com 1 1/8/2014 MPS Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. © 2014 MPS. All Rights Reserved.
