VLMRGB1500 www.vishay.com Vishay Semiconductors Multi SMD Chip LED RGBFEATURES • Utilizing high brightness AlInGaP and InGaN chip technologies • 4 pin RGB SMD LED package allows individual control of the driving current of each chip • Compact package outline dimensions (L x W x H in mm): 1.0 x 1.0 x 0.65 • Qualified according to JEDEC® moisture sensitivity level 3 • Compatible to IR reflow soldering DESCRIPTION • Operation temperature range: -40 °C to +85 °C The VLMRGB1500... is a high brightness tricolor LED • ESD-withstand voltage: up to 2 kV for red and 1 kV for designed primarily for RGB displays and backlights. It is blue and green according to JESD22-A114-B using the popular PCB based 0404 SMD package with 120° • Luminous intensities and colors categorized per reel emission characteristic. The 4 pin package with common • Material categorization: for definitions of compliance anode allows individual driving of each chip and thus a please see www.vishay.com/doc?99912 gapless coverage of a wide color space by additive color mixing. It provides high reliability in a temperature range APPLICATIONS from -40 °C to +85 °C, using highly suitable blue light stable package materials. • Telecommunication, office equipment, home appliances, industrial equipment, white goods PRODUCT GROUP AND PACKAGE DATA • Wide range of accent and decorative lighting • Product group: LED • Displays: full color message and displays video boards • Package: SMD 0404, 4 pin • Keyboard backlighting • Product series: RGB • Status indicator • Angle of half intensity: ± 60° • Signal and symbol illumination PARTS TABLELUMINOUSFORWARDWAVELENGTHINTENSITYat IVOLTAGEat IPARTCOLORF(nm)at IFF(mcd)TECHNOLOGY(mA)(mA)(V)(mA)MIN. TYP. MAX.MIN. TYP. MAX.MIN. TYP. MAX. Red 26 - 54 5 615 - 625 5 1.5 - 2.15 5 AlInGaP VLMRGB1500-GS08 True green 122 - 252 5 520 - 530 5 2.0 - 3.2 5 InGaN Blue 22 - 46 5 466 - 473 5 2.0 - 3.2 5 InGaN Note • Measurement accuracy: ± 11 % for luminous intensity, ± 1 nm for dominant wavelength, ± 0.1 V for forward voltage Rev. 1.1, 11-Sep-2025 1 Document Number: 80510 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
