Datasheet VLMRGB1500 (Vishay) - 7
ManufacturerVishay
DescriptionMulti SMD Chip LED RGB in 0404 package
Pages / Page9 / 7 — VLMRGB1500. SOLDERING PROFILE. FINAL PACKING. RECOMMENDED METHOD OF …
File Format / SizePDF / 443 Kb
VLMRGB1500. SOLDERING PROFILE. FINAL PACKING. RECOMMENDED METHOD OF STORAGE. BAR CODE PRODUCT LABEL. L E V E L. CAUTION
VLMRGB1500 SOLDERING PROFILE FINAL PACKING RECOMMENDED METHOD OF STORAGE BAR CODE PRODUCT LABEL L E V E L CAUTION
VLMRGB1500
SOLDERING PROFILE
Aluminum bag IR Reflow Soldering Profile for lead (Pb)-free Soldering Preconditioning acc. to JEDEC Level 3 Label 300 max. 260 °C 255 255 °C 250 245 °C 240 °C 217 °C 200 max. 30 s Reel 150 max. 120 s 150 s 15973 Temperature (°C) 100
FINAL PACKING
50 max. Ramp Up 3 °C/s max. Ramp Down 6 °C/s The sealed reel is packed into a cardboard box. A secondary 0 cardboard box is used for shipping purposes. 0 50 100 150 200 250 300 Time (s) max. 2 cycles allowed
Fig. 6 - Vishay Lead (Pb)-free Reflow Soldering Profile Dry box storage is recommended as soon as the aluminum According to J-STD-020 bag has been opened to prevent moisture absorption. The following conditions should be observed, if dry boxes are
(example) not available: • Storage temperature 10 °C to 30 °C • Storage humidity ≤ 60 % RH max. After more than 168 h under these conditions moisture VLMRGB1500-GS08 content will be too high for reflow soldering. 4000 In case of moisture absorption, the devices will recover to BBA/212 the former condition by drying under the following condition: 192 h at 40 °C + 5 °C / - 0 °C and < 5 % RH (dry air / nitrogen) or A. 2D bar code 96 h at 60 °C + 5 °C and < 5 % RH for all device containers B. Vishay part number or C. Quantity 24 h at 100 °C + 5 °C not suitable for reel or tubes. D. Selection code (bin): brightness and color groups An EIA JEDEC standard JESD22-A112 level 3 label is E. Code of manufacturing plant included on all aluminum dry bags. F. Termination plating finish G. Batch = date code: year / week / plant code
L E V E L CAUTION
H. Region code
This bag contains MOISTURE – SENSITIVE DEVICES 3
I. Internal serial number 1. Shelf life in sealed bag 12 months at <40°C and < 90% relative humidity (RH) J. Sales location 2. Peak package body temperature: 260°C K. ESD symbol 3. Vapor-phase reflow, or equivalent processing (peak package body temp. 260°C) must be: L. Lead (Pb)-free symbol a) Mounted within
168 hours
at factory condition of < 30°C/60%RH or b) Stored at < 10% RH. M. RoHS symbol, halogen-free symbol 4. Devices require baking before mounting if: a) Humidity Indicator Card is >10% when read at 23°C + 5°C or N. Internal lot numbers b) 2a or 2b is not met. 5. If baking is required, devices may be baked for:
DRY PACKING 192 hours
at 40°C + 5°C/-0°C and <5%RH (dry air/nitrogen)
or 96 hours
at 60±5oCand <5%RH For
all
device containers
or 24 hours
The reel is packed in an anti-humidity bag to protect the at 100±5°C Not suitable for
reels or tubes
devices from absorbing moisture during transportation and Bag Seal Date: _____________________________ _ (If blank, see bar code label) storage. Note: LEVEL defined by EIA JEDEC Standard JESD22-A112 23222 Example of JESD22-A112 level 3 label Rev. 1.1, 11-Sep-2025
7
Document Number: 80510 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
