Datasheet RP2040-Zero (Waveshare Electronics)
ManufacturerWaveshare Electronics
DescriptionLow-cost, high-performance Pico-like MCU board based on Raspberry Pi microcontroller RP2040
Pages / Page12 / 1 — RP2040-Zero. Overview. …
File Format / SizePDF / 862 Kb
RP2040-Zero. Overview. RP2040-Zero, A Low-Cost, High-Performance Pico-Like. MCU Board Based On Raspberry Pi Microcontroller
Datasheet RP2040-Zero Waveshare Electronics
RP2040-Zero Overview RP2040-Zero, A Low-Cost, High-Performance Pico-Like MCU Board Based On Raspberry Pi Microcontroller RP2040. Specification RP2040-Zero RP2040 microcontroller chip designed by Raspberry Pi in the United Kingdom. Dual-core Arm Cortex M0+ processor, flexible clock running up to 133 MHz. 264KB of SRAM, and 2MB of on-board Flash memory. USB-C connector, keeps it up to date, easier to use. The castellated module allows soldering direct to carrier boards. USB 1.1 with device and host support. Low-power sleep and dormant modes. Drag-and-drop programming using mass storage over USB. 29 × multi-function GPIO pins (20× via edge pinout, others via solder points). 2 × SPI, 2 × I2C, 2 × UART, 4 × 12-bit ADC, 16 × controllable PWM channels. Accurate clock and timer on-chip. Temperature sensor. Accelerated floating-point libraries on-chip. 8 × Programmable I/O (PIO) state machines for custom peripheral support. Pinouts
