Datasheet SS12, SS13, SS14, SS15, SS16 (Vishay) - 2
ManufacturerVishay
DescriptionSurface-Mount Schottky Barrier Rectifier in SMA (DO-214AC) package
Pages / Page5 / 2 — SS12, SS13, SS14, SS15, SS16. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST …
SS12, SS13, SS14, SS15, SS16. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITIONS SYMBOL. SS12. SS13. SS14. SS15. SS16. UNIT. Notes
SS12, SS13, SS14, SS15, SS16 ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITIONS SYMBOL SS12 SS13 SS14 SS15 SS16 UNIT Notes
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
Maximum instantaneous forward 1.0 A V (1) 0.50 0.75 V voltage F Maximum DC reverse current at TA = 25 °C 0.2 I mA rated DC blocking voltage R (2) TA = 100 °C 6.0 5.0
Notes
(1) Pulse test: 300 μs pulse width, 1 % duty cycle (2) Pulse test: pulse width ≤ 40 ms
THERMAL CHARACTERISTICS
PARAMETER SYMBOL SS12 SS13 SS14 SS15 SS16 UNIT
RθJA 88 Typical thermal resistance (1) °C/W RθJL 28
Note
(1) PCB mounted with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
SS16-E3/61T 0.064 61T 1800 7" diameter plastic tape and reel SS16-E3/5AT 0.064 5AT 7500 13" diameter plastic tape and reel SS16HE3_B/H (1) 0.064 H 1800 7" diameter plastic tape and reel SS16HE3_B/I (1) 0.064 I 7500 13" diameter plastic tape and reel SS16-M3/61T 0.064 61T 1800 7" diameter plastic tape and reel SS16-M3/5AT 0.064 5AT 7500 13" diameter plastic tape and reel SS16HM3_B/H (1) 0.064 H 1800 7" diameter plastic tape and reel SS16HM3_B/I (1) 0.064 I 7500 13" diameter plastic tape and reel
Note
(1) AEC-Q101 qualified Revision: 23-Apr-2020
2
Document Number: 88746 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
