Datasheet SS12, SS13, SS14, SS15, SS16 (Vishay) - 3
ManufacturerVishay
DescriptionSurface-Mount Schottky Barrier Rectifier in SMA (DO-214AC) package
Pages / Page5 / 3 — SS12, SS13, SS14, SS15, SS16. RATINGS AND CHARACTERISTICS CURVES
SS12, SS13, SS14, SS15, SS16 RATINGS AND CHARACTERISTICS CURVES
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted) Axis Title ) (A 100 10000 T 1.0 J = 150 °C ) A 10 (m Current 1 urrent TJ = 125 °C 1000 C 0.1 TJ = 75 °C e line lin 0.5 verse 0.01 e R 1st 2nd T s J = 25 °C 0.001 rward Rectified PCB Mounted on 0.2" x 0.2" 100 o (5.0 mm x 5.0 mm) Copper Pad Area 0.0001 e F SS12 thru SS16 stantaneou erag 0.00001 v In 0 T A J = -40 °C 0.000001 10 0 25 50 75 100 125 150 0 20 40 60 80 100 Lead Temperature (°C) Percent of Rated Peak Reverse Voltage (%) Fig. 1 - Forward Current Derating Curve Fig. 4 - Typical Reverse Characteristics 50 1000 At Rated TL T = 25 °C 8.3 ms Single Half Sine-Wave J f = 1.0 MHz 40 V = 50 mV sig p-p 30 tance (pF) 100 20 ard Surge Current (A) orw nction Capaci 10 ak F u e J P SS12 thru SS14 SS15 and SS16 0 10 1 10 100 0.1 1 10 100 Number of Cycles at 60 Hz Reverse Voltage (V) Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Fig. 5 - Typical Junction Capacitance Axis Title 100 10000 ) (A 10 rrent u T = 150 °C J 1000 C e rd a lin 1 orw F 2nd s T = 25 °C J 100 0.1 T = -40 °C J stantaneou In 0.01 10 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Instantaneous Forward Voltage (V) Fig. 3 - Typical Instantaneous Forward Characteristics Revision: 23-Apr-2020
3
Document Number: 88746 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
