Datasheet ALDP105 (Panasonic) - 2
ManufacturerPanasonic
DescriptionCompliant with IEC/EN60335-1, IEC/EN60079-15 1 Form A 5 A Slim power relays
Pages / Page10 / 2 — ALDP 1
File Format / SizePDF / 205 Kb
ALDP 1
ALDP 1
Power Relays ( Over 2 A ) LD-P RELAYS Compliant with IEC/EN60335-1, IEC/EN60079-15 1 Form A 5 A Slim power relays FEATURES Protective construction:Sealed ● Rated switching capacity: 5 A 277 V AC ● Ambient temperature: −40 to +85 ℃ ● Compact size: 6.9 mm ( W ) × 20.2 mm ( L ) 6.9 20. 20 2 . × 14.9 mm ( H ) 14. 14 9 . ● Compliant with IEC/EN60335-1*1 ( VDE approved ) EN60695 ( GWT2-11, GWFI2-12, GWIT2-1 ) data available *1: Common safety standard for major electrical appliance ● Compliant with IEC/EN60079-15*2 *2: Explosion-proof certification TYPICAL APPLICATIONS ● Boilers, Hot water units (Unit:mm) ● Air conditioner, Fan heaters ● Refrigerator ● Microwave ovens ORDERING INFORMATION ( PART NO. )
ALDP 1
Contact arrangement Coil insulation class Rated coil voltage (DC) Packing style 1:1 Form A Nil:Class E insulation Part No. 05 06 09 12 18 24 Nil:Tube F:Class F insulation W :Carton Rated coil voltage 5 6 9 12 18 24 Note) The "W" at the end of the part number only appears on the inner and outer packing. It does not appear on the relay itself. TYPES Part No. * Standard packing Contact arrangement Rated coil voltage Class E insulation Class F insulation Inner carton Outer carton 5 V DC ALDP105W ALDP1F05W 6 V DC ALDP106W ALDP1F06W 9 V DC ALDP109W ALDP1F09W Carton: 100 pcs. Carton: 500 pcs. 1 Form A Tube: 50 pcs. Tube: 1,000 pcs. 12 V DC ALDP112W ALDP1F12W 18 V DC ALDP118W ALDP1F18W 24 V DC ALDP124W ALDP1F24W * Tube packing types available. When ordering, please remove suffix " W ". Panasonic Industry Co., Ltd. Electromechanical Control Business Division industry.panasonic.com Panasonic Industry Co., Ltd. 2024 ASCTB193E 202410 ー 1 ー
