Datasheet ALDP105 (Panasonic) - 4
ManufacturerPanasonic
DescriptionCompliant with IEC/EN60335-1, IEC/EN60079-15 1 Form A 5 A Slim power relays
Pages / Page10 / 4 — Power. Relays. (. Over. 2. A. ). LD-P. RELAYS. REFERENCE. DATA. 1. Max. …
File Format / SizePDF / 205 Kb
Power. Relays. (. Over. 2. A. ). LD-P. RELAYS. REFERENCE. DATA. 1. Max. switching. capacity. 2. Coil. temperature. characteristics. (. Average. ). Tested
Power Relays ( Over 2 A ) LD-P RELAYS REFERENCE DATA 1 Max switching capacity 2 Coil temperature characteristics ( Average ) Tested
Power Relays ( Over 2 A ) LD-P RELAYS REFERENCE DATA 1. Max. switching capacity 2. Coil temperature characteristics ( Average ) Tested sample:ALDP112, 6 pcs. Measured portion:Coil inside Contact current:0A, 5A 10 50 *at * room temper at at room temper u at r u e r 5 ) AC resist AC ive resist l ive o l a o d a 5A A * * 5 40 (℃) 0A ( * * 0 rrent ise cu 85℃ ℃ 5A 5 act 1 85℃ ℃ 0A 0 30 perature r Cont Tem 20 0.110 100 1080 100 120 140 Contact voltage(V) Coil applied voltage(%V) 3-1. Operate time 3-2. Release time ( without diode ) 3-3. Release time ( with diode ) Tested sample:ALDP112, 30 pcs. Tested sample:ALDP112, 30 pcs. Tested sample:ALDP112, 30 pcs. 10 10 10 8 8 8 ) ) ) ms ms ms ( ( ( 6 6 6 ate time Max. ase time ase time Min. Oper 4 Rele 4 Rele 4 Max. Min. 2 2 2 Max. Min. 0 0 0 60 80 100 120 140 60 80 100 120 140 60 80 100 120 140 Coil applied voltage(%V) Coil applied voltage(%V) Coil applied voltage(%V) 4. Electrical life test ( 5 A 250 V AC Resistive load ) Tested sample:ALDP112, 6 pcs. Change of operate and release voltage Change of contact resistance Operation frequency:20 times/min. 10 100 (ON:OFF=1.5s:1.5s) Ambient temperature:20℃ ) V 9 90 Circuit: ( 8 Ω) 80 Operate v Oper o ate v lt o age lt m detection c and welding detection C voltage 7 Max. (e 70 ont Mi act ase 6 Min. 60 istanc s-c rele 5 res 50 250V AC ont ircuit 12V DC acting 4 act 40 ate and 3 Cont 30 Oper 2 Rele R a ele se v a o se v lt o age lt 20 Max. Max. 1 Min. 10 Min. 0 0 0 10 0 10 No. of operations(×104) No. of operations(×104) Panasonic Industry Co., Ltd. Electromechanical Control Business Division industry.panasonic.com Panasonic Industry Co., Ltd. 2024 ASCTB193E 202410 ー 3 ー
