Datasheet LTC7899 (Analog Devices) - 3
Description140V, Low IQ, Negative to Positive Synchronous Boost Controller with 10V Gate Drive in 28-Lead QFN (4mm x 4mm x 0.75mm w/ EP) package
Pages / Page50 / 3 — Data Sheet. LTC7899. REVISION HISTORY. REVISION. PAGE. DESCRIPTION. …
Data Sheet. LTC7899. REVISION HISTORY. REVISION. PAGE. DESCRIPTION. NUMBER. DATE. analog.com
Data Sheet LTC7899 REVISION HISTORY REVISION PAGE DESCRIPTION NUMBER DATE analog.com
link to page 31 link to page 32 link to page 33 link to page 33 link to page 34 link to page 34 link to page 36 link to page 36 link to page 37 link to page 37 link to page 37 link to page 38 link to page 39 link to page 41 link to page 41 link to page 43 link to page 47 link to page 48 link to page 49
Data Sheet LTC7899
Power MOSFET Selection ... 31 CIN and COUT Selection ... 32 Setting the Output Voltage .. 33 RUN Pin and Undervoltage Lockout ... 33 Soft-Start (SS Pin) ... 34 DRVCC and INTVCC Regulators (OPTI-DRIVE) ... 34 Topside MOSFET Driver Supply (CB, DB) ... 36 Minimum On-Time Considerations ... 36 Fault Conditions: Overtemperature Protection ... 37 Phase-Locked Loop and Frequency Synchronization ... 37 Efficiency Considerations ... 37 Checking Transient Response ... 38 Design Example .. 39 PC Board Layout Checklist ... 41 PC Board Layout Debugging .. 41 Typical Application .. 43 Related Parts .. 47 Outline Dimensions ... 48 Ordering Guide ... 49
REVISION HISTORY REVISION REVISION PAGE DESCRIPTION NUMBER DATE NUMBER
0 7/25 Initial release —
analog.com
Rev. 0 3 of 50 Document Outline Features Applications General Description Typical Application TABLE OF CONTENTS Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Block Diagram Typical Performance Characteristics Theory of Operation Main Control Loop Power and Bias Supplies (VBIAS, EXTVCC, DRVCC, and INTVCC) High-Side Bootstrap Capacitor Dead Time Control (DTCA and DTCB Pins) Start-Up and Shutdown (RUN and SS Pins) Light Load Operation: Burst Mode Operation, Pulse-Skipping Mode, or Forced Continuous Mode (MODE Pin) Frequency Selection, Spread Spectrum, and Phase-Locked Loop (FREQ and PLLIN/SPREAD Pins) PolyPhase Applications (CLKOUT and PHASMD Pins) Output Overvoltage Protection Operation at Low Input Voltage BOOST Supply Refresh Power Good Applications Information Inductor Value Calculation Inductor Core Selection Current Sense Selection Low Value Resistor Current Sensing Inductor DCR Current Sensing Setting the Operating Frequency Selecting the Light Load Operating Mode Dead Time Control (DTCA and DTCB Pins) DTCx Pins Tied to INTVCC or VIN- (Adaptive Dead Time Control) DTCx pin connected with a resistor to VIN-: Power MOSFET Selection CIN and COUT Selection Setting the Output Voltage RUN Pin and Undervoltage Lockout Soft-Start (SS Pin) DRVCC and INTVCC Regulators (OPTI-DRIVE) Topside MOSFET Driver Supply (CB, DB) Minimum On-Time Considerations Fault Conditions: Overtemperature Protection Phase-Locked Loop and Frequency Synchronization Efficiency Considerations Checking Transient Response Design Example PC Board Layout Checklist PC Board Layout Debugging Typical Application Related Parts Outline Dimensions Ordering Guide
