Datasheet IP101G (IC Plus) - 6
| Manufacturer | IC Plus |
| Description | Single Port 10/100 MII/RMII/TP/Fiber Fast Ethernet Transceiver |
| Pages / Page | 66 / 6 — Revision History. Revision #. Change Description |
| File Format / Size | PDF / 1.7 Mb |
IP101G Data Sheet
Revision History Revision # Change Description
IP101G-DS-R01 Initial release. IP101G-DS-R01-20120808 1) Correct the I/O type of IP101GA pin description to O(Ouput) for pin24 RXER. 2) Change the pin name from DVDD33_IO to VDDIO. IP101G-DS-R01-20120821 1) Change the default value of register P16R27 from 0x0022 to 0x0012. 2) Remove I/O Slew Rate Control Register. 3) Change the register location RMII_WITH_ER from P16R29[0] to P16R29[7]. IP101G-DS-R01-20120927 1) Add more description of low power idle (LPI) state in MII and RMII modes. 2) Correct the typo of Physical Dimensions. IP101G-DS-R01-20121101 Change the LED blink timing from “On 80ms -> Off (20~40)ms” to “On 26ms -> Off 78ms”. IP101G-DS-R01-20121113 Add more function description to support Jumbo Frame. IP101G-DS-R01-20121127 Change the LED mode function as same as IP101A. IP101G-DS-R01-20121224 Add the notice that does not let these PHY address pins floating for the latched-in settings after the power is ready. IP101G-DS-R01-20130206 Change the AC timing Tclk_MII_rdy in Table 14 from 10ms Min. to 10ms Max. IP101G-DS-R01-20130312 1) Add more Min. and Max value on the AC Timing table. 2) Add thermal data on the Table 20. IP101G-DS-R01-20130507 Add LED Pin Driving Control Register. IP101G-DS-R01-20130621 Add IP101GRI 2.5V I/O power supply. IP101G-DS-R01-20130712 Modify WOL+ programming guide. IP101G-DS-R01-20130830 Modify Magic packet MAC_Address description. IP101G-DS-R01-20130905 Modify LED Control Register. IP101G-DS-R01-20130927 Modify MDC clock period can be to 300ns. IP101G-DS-R01-20131110 Add the symbol "Bottom view" and "Top view" in Physical Dimensions. IP101G-DS-R01-20131115 Add Equivalent Series Resistance and Drive Level in Crystal Specifications. IP101G-DS-R01-20140114 1) Make more clear between 100Mbps (25M nibbles/s) and 25M code-groups/s in Figure 1 Flow chart of IP101G. 2) Change all symbols from “VQFN” to “QFN”. 3) Add the key word “Fiber” in Table 11 I/O Electrical Characteristics. 4) Add register PHY_ADDRESS in Page16 Reg29 bit[12:8]. 5) Add Table 20 MDI to MII latency delay time. 6) Add table 5 PHY Address Configuration by register description IP101G-DS-R01-20140224 Modify Register4 Next Page bit symbol “RO” to “RW”. IP101G-DS-R01-20140328 Delete termination resistors description of Layout Guideline 6.2. IP101G-DS-R01-20140520 1) Modify UTP PHY Interrupt control/status Register description. 2) Add special Reset request description.
Disclaimer This document probably contains the inaccurate data or typographic error. In order to keep this document correct, IC Plus reserves the right to change or improve the content of this document.
6/66 May 20, 2014 Copyright © 2011, IC Plus Corp. IP101G-DS-R01 Document Outline Features comparison between IP101G and IP101A/IP101AH 1 Pin diagram 2 Dice pad information 3 Pin description 3.1 IP101GA pin description 3.2 IP101GR/GRI pin description 4 Register Descriptions 4.1 Register Page mode Control Register 4.2 MII Registers 4.3 MMD Control Register 4.4 MMD Data Register 4.5 RX Counter Register 4.6 LED Pin Control Register 4.7 WOL+ Control Register 4.8 UTP PHY Specific Control Register 4.9 Digital IO Pin Control Register 5 Function Description 5.1 Major Functional Block Description 5.1.1 Transmission Description 5.1.2 MII and Management Control Interface 5.1.3 RMII Interface 5.1.4 Flexible Clock Source 5.1.5 Auto-Negotiation and Related Information 5.1.6 Auto-MDIX function 5.2 PHY Address Configuration 5.3 Power Management Tool 5.3.1 Auto Power Saving Mode 5.3.2 IEEE802.3az EEE (Energy Efficient Ethernet) 5.3.3 Force power down 5.3.4 WOL+ operation mode 5.4 LED Mode Configuration 5.5 LED Blink Timing 5.6 Repeater Mode 5.7 Interrupt 5.8 Miscellaneous 5.9 Serial Management Interface 5.10 Fiber Mode Setting 5.11 Jumbo Frame 6 Layout Guideline 6.1 General Layout Guideline 6.2 Twisted Pair recommendation 7 Electrical Characteristics 7.1 Absolute Maximum Rating 7.2 DC Characteristics 7.3 Crystal Specifications 7.4 AC Timing 7.4.1 Reset, Pin Latched-in, Clock and Power Source 7.4.2 MII Timing 7.4.3 RMII Timing 7.4.4 SMI Timing 7.4.5 MDI to MII latency delay time 7.5 Thermal Data 8 Order Information 9 Physical Dimensions 9.1 48-PIN LQFP 9.2 32-PIN QFN
