Datasheet IP175LLF (IC Plus)
ManufacturerIC Plus
Description5 Port 10/100 Ethernet Integrated Switch in 68-pin QFN package
Pages / Page116 / 1 — 5 Port 10/100 Ethernet Integrated Switch. (Loop Detection, Layer 2-4 MF …
5 Port 10/100 Ethernet Integrated Switch. (Loop Detection, Layer 2-4 MF Classifier, HW IGMP Snooping). Features General
Datasheet IP175LLF IC Plus
IP175LLF Datasheet
5 Port 10/100 Ethernet Integrated Switch (Loop Detection, Layer 2-4 MF Classifier, HW IGMP Snooping) Features General Description
z Wide operating temperature range IP175LLF integrates a 5-port switch - IP175LLF (0°C to 70°C) controller, SSRAM, and 4 10/100 Ethernet transceivers. Each of the transceivers compliers - IP175LLFI (-40°C to 85°C) z with the IEEE802.3, IEEE802.3u, and Built in 5 MAC and 4 PHY z IEEE802.3x specifications. The DSP approach is Each port can be configured to be 10Based-T, 100Base-TX utilized for designing transceivers with 0.16um z technology; they have high noise immunity and Up to 2K MAC addresses z robust performance. Support auto-polarity for 10Mbps z IP175LLF operates in store and forward Broadcast storm protection z mode. IP175LLF have a lot of rich feature for Auto MDI-MDIX z different application, include router application, Support one MII/RMII port z firewall, IEEE 802.1Q, IGMP snooping, Layer2-4 Multi-Field classifier policy-based QoS. It provides powerful QoS - Support 8-MultiField entry function, include traffic policy, traffic meter, and - Support traffic policy flexible queue scheduling (WRR/WFQ/SP). In - Support Multi-Filed filter virtual LAN, IP175LLF support port-based VLAN - Support copy to mirror port and IEEE 802.1Q tag-tagged VLAN (up to 16 - Support trap to CPU port z VLAN groups). Class of Service IP175LLF support up to 2K MAC addresses, - Port based, MAC address, VID, VLAN priority, IPv4 ToS, IPv6 DSCP,TCP/UDP up to 16 VLANs and up to 8 Multi-Field entries. logical port and Multi-Field These tables are accessible through MII register. z The address table can configure either “2K QoS unicast addresses” or “1K unicast addresses and - Support policy-based QoS 1K multicast addresses“. The Multi-Field - Support 4-level priority queues per port classification is powerful classifier (layer2 to layer - WRR/WFQ/SP z 4 packet headers) in packet classification. The Support hardware IGMP v1,v2 snooping z classifier divides incoming packets into multiple Support Port mirror z classes based on prescribed rules. Each traffic Support 16 VLAN (IEEE Std 802.1q) class from classifier can drop out-of-profile - Port-based/tagged-based VLAN packets, monitor traffic, specify forwarding - Shared/Independent VLAN Learning behavior, and specify output queue. - Support insert, remove tag Beside a 5-port switch application, IP175LLF - Support VLAN priority remarking z supports one MII/RMII ports for router Support STP, RSTP and MSTP z application. The external MAC can monitor or Support port-based access control z configure IP175LLF by accessing MII registers Supports rate control(WFQ) through SMI0. - In/Out port rate control MII/RMII port also can be configured to be - Traffic Policy z MAC mode. It is used to interface an external Interrupt Pin z PHY to work as 4+1 switch. Support special tag and QinQ header z Support Link quality LED for 100Mbps z Support direct LED z Built in Linear regulator control register z
Support auto power saving mode
z 0.16um, 68-pin QFN Lead Free package 1/116 April 11, 2018 Copyright © 2007, IC Plus Corp. IP175LLF-DS-R04 Document Outline Comparison Table between IP175D and IP175LLF 1 Pin Diagram 1.1 IP175LLF Pin diagram (QFN68) 2 Pin Description 3 Function Description 3.1 Flow Control 3.2 Broadcast Storm Protection 3.3 Rate Control 3.4 External MII 3.4.1 To define the speed, duplex and pause of MII port 3.4.2 The Application Circuit of RMII 3.5 Virtual LAN (VLAN) 3.5.1 Port-based VLAN 3.5.2 Tag-based VLAN 3.5.3 VLAN Ingress Filtering 3.5.4 Shared and Independent VLAN Learning 3.5.5 The determination of the requirement to insert or remove tag 3.6 Quality of Service (QoS) 3.6.1 Traffic Policy 3.6.2 Priority Classification 3.6.3 Output Queue Scheduling 3.7 Port mirror 3.8 Layer 2-4 Multi-Field Classification 3.9 MAC Address Table 3.9.1 Entry Content 3.9.2 Accessing MAC Table 3.10 CPU Interrupt Control for loop detection 3.11 IGMP Snooping 3.12 Security Filtering 3.12.1 Physical Port Filtering 3.12.2 MAC Address Filtering 3.12.3 Logical Port Filtering 3.12.4 Layer 2-4 Multi-Field Filtering 3.13 IEEE 802.1x 3.14 Spanning Tree 3.15 Special Tag 3.16 Loop Detection 3.17 LED Blink Timing 3.18 Serial Management Interface 3.19 Reset 3.20 Built in regulator 4 PHY Register 4.1 PHY ID Map 4.2 PHY 0~3 and 5 Register Map 4.3 MII Register 0 4.3.1 MII Register 0 of PHY0~3 4.3.2 MII Register 0 of PHY5 4.4 MII Register 1 4.4.1 MII Register 1 of PHY0~3 4.4.2 MII Register 1 of PHY5 4.5 MII Register 2 of PHY0~3 (4 PHYs share the MII register) 4.6 MII Register 3 of PHY0~3 (4 PHYs share the MII register) 4.7 MII Register 4 4.7.1 MII Register 4 of PHY0~3 4.7.2 MII Register 4 of PHY5 4.8 MII Register 5 4.8.1 MII Register 5 of PHY0~3 4.8.2 MII Register 5 of PHY5 4.9 MII Register 6 of PHY0~3 4.10 MII Register 16 of PHY0~3 (4 PHYs share the MII register) 4.11 MII Register 18 of PHY0~3 4.12 MII Register 22 of PHY0~3 (4 PHYs share the MII register) 5 Switch Register 5.1 Switch Register Map 5.2 Switch Register EEPROM Map 5.3 Switch Control Register 5.3.1 Chip Identification 5.3.2 Software Reset Register 5.3.3 MII Force Mode 5.3.4 Congestion Control Register 5.3.5 Port State 5.3.6 Illegal Frame Filter 5.3.7 Special Packet Identification 5.3.7.1 Reserved Address 01-80-C2-00-00-00 to 01-80-C2-00-00-1F 5.3.7.2 Reserved Address 01-80-C2-00-00-20 to 01-80-C2-00-00-FF 5.3.7.3 Miscellaneous Special Packet Identification 5.3.8 Network Security 5.3.9 Learning Control Register 5.3.10 Aging Time Parameter 5.3.11 Broadcast Storm Protection 5.3.12 Port Mirror 5.3.13 Source Block Protection 5.3.14 LED Control Register 5.4 External MII Control Register 5.4.1 External MII Status Report Register 5.4.2 MII0 MAC Mode Register 5.4.3 MII0 Control Register 1 5.4.4 MII0 Control Register 2 5.5 IGMP Control Register 5.5.1 Base Control Register 5.5.2 Router Port Timeout 5.5.3 IGMP Group Timeout 5.6 Rate Control 5.6.1 Basic Rate Setting Register 5.6.2 Rate Setting Access Control Register 5.7 Address Table Access Register 5.7.1 Command Register 5.7.2 Data Buffer Register (For Unicast MAC Address) 5.7.3 Data Buffer Register (For Multicast MAC Address) 5.7.4 Data Buffer Register (For IP Multicast Address) 5.8 CPU Interrupt Register 5.8.1 CPU Interrupt Control Register 5.8.2 Loop detection enable Register 5.8.3 Loop port indicator Register 5.9 Miscellaneous Control Register 5.10 CRC Counter 5.11 VLAN Group Control Register 5.11.1 VLAN Classification 5.11.2 VLAN Ingress Rule 5.11.3 VLAN Egress Rule 5.11.4 Default VLAN Information 5.11.5 VLAN Table 5.11.5.1 VLAN Control Register 5.11.5.2 VLAN Identifier Register 5.11.5.3 VLAN Member Register 5.11.5.4 Add Tag Control Register 5.11.5.5 Remove Tag Control Register 5.11.5.6 VLAN Miscellaneous Register 5.11.5.7 Spanning Tree Table 5.12 Quality of Service (QOS) 5.12.1 Priority Classification 5.12.1.1 Base Control Register 5.12.1.2 Port Priority Map 5.12.1.3 VLAN Priority Map 5.12.1.4 TOS/DSCP Priority Map 5.12.1.5 TCP/UDP Port Priority 5.12.2 Queue Scheduling Configuration Register 5.13 QoS Multi-Field Classification 5.13.1 Multi-Field Classification Table Control Register 5.13.2 Multi-Field Classification Register 5.13.3 Multi-Field Table QoS Rate Control Register 5.13.4 Multi-Field Access Control Register 5.13.5 Multi-Field Status Register 5.14 Auto Blocking/Recovery loop port 6 Crystal Specifications 7 Electrical Characteristics 7.1 Absolute Maximum Rating 7.2 DC Characteristic 7.3 AC Timing 7.3.1 Power On Sequence and Reset Timing 7.3.2 PHY Mode MII (Turbo MII) Timing 7.3.3 MAC Mode MII (Turbo MII) Timing 7.3.4 RMII Timing 7.3.5 SMI Timing 7.3.6 EEPROM Timing 7.4 Thermal Data 8 Order Information 9 Package Detail 68 QFN Outline Dimensions 9.2 68 QFN PCB footprint
