Datasheet TIP41A (STMicroelectronics) - 3
DescriptionNPN Power Transistor in TO-220 package
Pages / Page10 / 3 — TIP42A. 2 Electrical. Characteristics. Table 2. Electrical …
File Format / SizePDF / 207 Kb
TIP42A. 2 Electrical. Characteristics. Table 2. Electrical Characteristics. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit
TIP42A 2 Electrical Characteristics Table 2 Electrical Characteristics Symbol Parameter Test Conditions Min Typ Max Unit
TIP42A
Tcase = 25°C; unless otherwise specified
Table 2. Electrical Characteristics Symbol Parameter Test Conditions Min. Typ. Max. Unit
ICEO Collector Cut-off Current (IB = 0) VCE = 30 V 0.7 mA IEBO Emitter Cut-off Current (IC = 0) VEB = 5V 1 mA ICES Collector Cut-off Current (VBE = 0) VCE = 60V 0.4 mA VCEO(sus) Collector-Emitter IC = 30mA 60 V Note: 1 Sustaining Voltage (IB = 0) VCE(sat) Collector-Emitter saturation Voltage IC = 6A __ ___ I B = 0.6A 1.5 V Note: 1 VBE(on) Base-Emitter Voltage IC = 6A _____ VCE = 4V 2 V Note: 1 hFE IC = 0.3A _ VCE = 4V 30 DC Current Gain Note: 1 IC = 3A _ VCE = 4V 15 75 IC = 0.5A VCE = 10V f=1 KHz 20 hfe Small Signal Current Gain IC = 0.5A VCE = 10V f=1 KHz 3 Note: 1 Pulsed duration = 300 μs, duty cycle ≤1.5%. For PNP types voltage e current values are negative. 3/10 Document Outline 1 Absolute Maximum Ratings Table 1. Absolute Maximum Ratings 2 Electrical Characteristics Table 2. Electrical Characteristics 2.1 Typical Characteristic Figure 1. DC Current Gain (NPN) Figure 2. DC Current Gain (PNP) Figure 3. DC Current Gain (NPN) Figure 4. DC Current Gain (PNP) Figure 5. Collector-Emitter Saturation Voltage (NPN) Figure 6. Collector-Emitter Saturation Voltage (PNP) Figure 7. Base-Emitter Saturation Voltage (NPN) Figure 8. Base-Emitter Saturation Voltage (PNP) Figure 9. BT(ON) Time (NPN) Figure 10. BT(ON) Time (PNP) Figure 11. Resistive Load Switching Time (NPN) Figure 12. Resistive Load Switching Time (PNP) Figure 13. Resistive Load Switching Time (NPN) Figure 14. Resistive Load Switching Time (PNP) Figure 15. Collector-Base and Collector- Emitter Capacitance (NPN) Figure 16. Collector-Base and Collector- Emitter Capacitance (PNP) 3 Package Mechanical Data 4 Revision History
