Datasheet 40 LHE (Vishay) - 6
ManufacturerVishay
DescriptionLinear Position Sensor in Hall Effect Technology (0 mm to 40 mm Max.) 40 LHE
Pages / Page7 / 6 — 40 LHE. WITH SPRING RETURN. WIRE
File Format / SizePDF / 151 Kb
40 LHE WITH SPRING RETURN WIRE
40 LHE
www.vishay.com Vishay Sfernice
WITH SPRING RETURN
Fully extended: 87 ± 2 20 Mechanical stroke 41 min. 2 x 16.5 35 max. 12 11.9 2 x Ø 3.1 4 9.8 14.5 M5 Front face 28 4 - 0.01 - 0.03 Bottom face Ø 5 Gen. tol.: ± 0.5 mm
WIRE
YELLOW GND (-) RED SIGNAL GREEN Vcc (+) Revision: 12-Jun-2025
6
Document Number: 57124 For technical questions, contact: sferprecisionpot@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
