Datasheet L78 (STMicroelectronics) - 9
DescriptionPositive voltage regulator ICs
Pages / Page55 / 9 — L78. Electrical characteristics. Table 6. Electrical characteristics of …
File Format / SizePDF / 3.3 Mb
L78. Electrical characteristics. Table 6. Electrical characteristics of L7809A. Symbol. Parameter. Test conditions. Min. Typ. Max. Unit
L78 Electrical characteristics Table 6 Electrical characteristics of L7809A Symbol Parameter Test conditions Min Typ Max Unit
link to page 9 link to page 9
VI = 15 V, IO = 1 A, TJ = 0 to 125 °C (L7809AC), TJ = -40 to 125 °C (L7809AB), unless otherwise specified(Minimum load current for regulation is 5 mA.)
Table 6. Electrical characteristics of L7809A Symbol Parameter Test conditions Min. Typ. Max. Unit
VO Output voltage TJ = 25 °C 8.82 9 9.18 V VO Output voltage IO = 5 mA to 1 A, VI = 11.5 to 22 V 8.65 9 9.35 V VO Output voltage IO = 1 A, VI = 22 to 24 V, TJ = 25 °C 8.65 9 9.35 V VI = 10.6 to 25 V, IO = 500 mA, TJ = 25 °C 12 90 mV VI = 11 to 17 V 15 90 mV ∆V (1) O Line regulation VI = 11 to 17 V, TJ = 25 °C 5 45 mV VI = 11.4 to 23 V, TJ = 25 °C 12 90 mV IO = 5 mA to 1 A 25 100 ∆V (1) O Load regulation IO = 5 mA to 1.5 A, TJ = 25 °C 30 100 mV IO = 250 to 750 mA 10 50 TJ = 25 °C 4.3 6 mA Iq Quiescent current 6 mA VI = 11 to 25 V, IO = 500 mA 0.8 mA ∆Iq Quiescent current change VI = 10.6 to 23 V, TJ = 25 °C 0.8 mA IO = 5 mA to 1 A 0.5 mA SVR Supply voltage rejection VI = 11.5 to 21.5 V, f = 120 Hz, IO = 500 mA 61 dB Vd Dropout voltage IO = 1 A, TJ = 25 °C 2 V eN Output noise voltage TA = 25 °C, B =10 Hz to 100 kHz 10 µV/VO RO Output resistance f = 1 kHz 18 mΩ Isc Short circuit current VI = 35 V, TA = 25 °C 0.2 A Iscp Short circuit peak current TJ = 25 °C 2.2 A ∆VO/∆T Output voltage drift -0.8 mV/°C 1. Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Note: Minimum load current for regulation is 5 mA.
DS0422
Rev 38 page 9/55
Document Outline L78 1 Diagram 2 Pin configuration 3 Maximum ratings 4 Test circuits 5 Electrical characteristics 6 Application information 6.1 Design consideration 7 Typical performance 8 Package information 8.1 TO-220 (dual gauge) package information 8.2 TO-220 (single gauge) package information 8.3 TO-220FP type A package information 8.4 TO-220 (single/dual) packing information 8.5 DPAK package information 8.6 D²PAK (SMD 2L STD-ST) type A package information 8.7 D²PAK (ASE) type B package information 8.8 D²PAK and DPAK packing information 9 Ordering information Revision history Contents List of tables List of figures
