Datasheet 2N5060, 2N5061, 2N5062, 2N5064 (ON Semiconductor) - 7
| Manufacturer | ON Semiconductor |
| Description | Sensitive Gate Silicon Controlled Rectifiers 0.8 A RMS in TO-92 package |
| Pages / Page | 9 / 7 — PACKAGE DIMENSIONS. TO−92 (TO−226). SCALE 1:1. SEATING. INCHES. … |
| File Format / Size | PDF / 208 Kb |
PACKAGE DIMENSIONS. TO−92 (TO−226). SCALE 1:1. SEATING. INCHES. MILLIMETERS. PLANE. DIM. MIN. MAX. X X. SECTION X−X. STYLES ON PAGE 2
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS TO−92 (TO−226)
CASE 29−11
SCALE 1:1
ISSUE AM DATE 09 MAR 2007 1 1 2 2 3 3 STRAIGHT LEAD BENT LEAD BULK PACK TAPE & REEL AMMO PACK NOTES:
A B
STRAIGHT LEAD 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. BULK PACK 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R
R
IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P AND
P
BEYOND DIMENSION K MINIMUM.
L SEATING INCHES MILLIMETERS PLANE K DIM MIN MAX MIN MAX A
0.175 0.205 4.45 5.20
B
0.170 0.210 4.32 5.33
C
0.125 0.165 3.18 4.19
D
0.016 0.021 0.407 0.533
D X X G
0.045 0.055 1.15 1.39
G H
0.095 0.105 2.42 2.66
J
0.015 0.020 0.39 0.50
H J K
0.500 --- 12.70 ---
V L
0.250 --- 6.35 ---
C N
0.080 0.105 2.04 2.66
SECTION X−X P
--- 0.100 --- 2.54
R
0.115 --- 2.93 ---
1 N V
0.135 --- 3.43 ---
N
NOTES:
A B
BENT LEAD 1. DIMENSIONING AND TOLERANCING PER
R
ASME Y14.5M, 1994. TAPE & REEL 2. CONTROLLING DIMENSION: MILLIMETERS. AMMO PACK 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P
P
AND BEYOND DIMENSION K MINIMUM.
T MILLIMETERS SEATING K PLANE DIM MIN MAX A
4.45 5.20
B
4.32 5.33
C
3.18 4.19
D
0.40 0.54
D X X G
2.40 2.80
G J
0.39 0.50
K
12.70 ---
J N
2.04 2.66
V P
1.50 4.00
C R
2.93 ---
SECTION X−X V
3.43 ---
1 N STYLES ON PAGE 2 DOCUMENT NUMBER: 98ASB42022B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TO−92 (TO−226) PAGE 1 OF 2 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 1998 www.onsemi.com
