Datasheet LTC7892 (Analog Devices) - 3
DescriptionLow IQ, Dual, 2-Phase Synchronous Boost Controller for GaN FETs in 40-Lead QFN (6mm x 6mm, Plastic Side Wettable) package
Pages / Page50 / 3 — Data Sheet. LTC7892. REVISION HISTORY. REVISION. PAGES. DESCRIPTION. …
Data Sheet. LTC7892. REVISION HISTORY. REVISION. PAGES. DESCRIPTION. NUMBER. DATE. CHANGED. analog.com
Data Sheet LTC7892 REVISION HISTORY REVISION PAGES DESCRIPTION NUMBER DATE CHANGED analog.com
link to page 35 link to page 36 link to page 36 link to page 36 link to page 38 link to page 39 link to page 39 link to page 39 link to page 39 link to page 40 link to page 41 link to page 43 link to page 45 link to page 46 link to page 47 link to page 48 link to page 49
Data Sheet LTC7892
Setting the Output Voltage ... 35 RUNx Pins and Undervoltage Lockout ... 36 Soft Start (SSx Pins) .. 36 INTVCC Regulators (OPTI-DRIVE) ... 36 Topside FET Driver Supply (CB) ... 38 Minimum On-Time Considerations .. 39 Fault Conditions: Overtemperature Protection .. 39 Phase-Locked Loop and Frequency Synchronization .. 39 Efficiency Considerations ... 39 Checking Transient Response .. 40 Design Example ... 41 PCB Board Layout Checklist ... 43 PCB Layout Debugging ... 45 Typical Applications .. 46 Related Parts .. 47 Outline Dimensions ... 48 Ordering Guide ... 49
REVISION HISTORY REVISION REVISION PAGES DESCRIPTION NUMBER DATE CHANGED
0 12/24 Initial release —
analog.com
Rev. 0 3 of 50 Document Outline Features Applications General Description Typical Application Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Diagram Theory of Operation Main Control Loop Power and Bias Supplies (VBIAS, EXTVCC, DRVCC, INTVCC) High Side Bootstrap Capacitor Dead Time Control (DTCA and DTCB Pins) Start-Up and Shutdown (RUN and SS Pins) Light Load Operation: Burst Mode Operation, Pulse-Skipping Mode, or Forced Continuous Mode (MODE Pin) Frequency Selection, Spread Spectrum, and Phase-Locked Loop (FREQ and PLLIN/SPREAD Pins) Output Overvoltage Protection Power Good Applications Information Inductor Value Calculation Inductor Core Selection Current Sense Selection Low Value Resistor Current Sensing Inductor DCR Current Sensing Setting the Operating Frequency Selecting the Light-Load Operating Mode Dead Time Control (DTCA and DTCB Pins) DTCx Pin Tied to Ground (Adaptive Dead Time Control) DTCx Pin connected with a resistor to GND Power FET Selection CIN and COUT Selection Single Output 2-Phase Operation Setting the Output Voltage RUNx Pins and Undervoltage Lockout Soft Start (SSx Pins) INTVCC Regulators (OPTI-DRIVE) Topside FET Driver Supply (CB) Minimum On-Time Considerations Fault Conditions: Overtemperature Protection Phase-Locked Loop and Frequency Synchronization Efficiency Considerations Checking Transient Response Design Example PCB Board Layout Checklist PCB Layout Debugging Typical Applications Related Parts Outline Dimensions Ordering Guide
