34 THE www.vishay.com Vishay Spectrol Ten Turns Servo or Bushing Mount Hall EffectSensor in Size 09 (22.2 mm)FEATURES • All electrical angles available up to: 3600° • Accurate linearity down to: ± 0.5 % • Very long life: 50M cycles for servo, 10M cycles for bushing • Non contacting technology: Hall effect; true power on sensor • Model dedicated to applications requiring long life QUICK REFERENCE DATA • Material categorization: For definitions of compliance Sensor type Multi Turn ROTATIONAL, hall effect please see www.vishay.com/doc?99912 Output type Wires or rear turrets Market appliance Industrial Dimensions 7/8" (22.2 mm) ELECTRICAL SPECIFICATIONSPARAMETERSTANDARDSPECIAL Electrical angle 10 turns 3600° Any other angle upon request Linearity ± 1 % ± 0.5 % Supply voltage 5 VDC ± 10 % Other upon request Supply current < 16 mA for single < 32 mA for redundant Analog ratiometric 1 % to 99 % of V Output signal supply (other on request) or PWM 1 kHz, 10 % to 90 % duty cycle or SPI binary on 5 V or binary on 3.3 V Over voltage protection + 20 VDC Reverse voltage protection - 10 VDC Load resistance recommended Min. 1 k for analog output and PWM output Hysteresis static 10° on drive shaft MECHANICAL SPECIFICATIONSPARAMETER Mechanical travel 3600° continuous Bearing type A sleeve bearing for bushing model/2 ball bearings for servo model Standard IP 50; other on request Resolution 12 bits for analog and PWM, 14 bits for SPI ORDERING INFORMATION/DESCRIPTION34 THEB1ATA2S22XXXXBO 1e1 MOUNTING NUMBER OF OUTPUT OUTPUT SHAFT SPECIAL LEAD MODEL LINEARITY PACKAGING TYPE SIGNALS TYPE SIGNAL TYPE REQUEST FINISH B : Bushing 1 : Single A : ± 1 % T : Turrets A : Analog CW 2 : 3.175 mm Box of S : Servo 2 : Redundant B : ± 0.5 % Z : Custom B : Analog CCW 9 : Special 1 piece W : Wires C : PWM CW P : Plain D : PWM CCW S : Slotted E : SPI CW (1) Z : Other type F : SPI CCW (1) G : Analog inverted slope H : PWM inverted slope K : SPI inverted slope (1) Z : Other output Shaft length from mounting face standard: 22 mm Note (1) SPI output output type: Wires SAP PART NUMBERING GUIDELINES34 THES2BTC2P12XXXX SERVO 2 OUTPUT OUTPUT OUTPUT SHAFT SPECIAL MODEL LINEARITY TYPE SIGNALS TYPE SIGNAL TYPE REQUEST B: ± 0.5 % Revision: 25-Jul-12 1 Document Number: 57114 For technical questions, contact: sferprecisionpot@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
