Datasheet 34 THE (Vishay) - 2
ManufacturerVishay
DescriptionTen Turns Servo or Bushing Mount Hall Effect Sensor in Size 09 (22.2 mm)
Pages / Page7 / 2 — 34 THE. VOUT ANALOG. Single Output. 99 %. Output S1. supply. 50 %. (% V. …
File Format / SizePDF / 231 Kb
34 THE. VOUT ANALOG. Single Output. 99 %. Output S1. supply. 50 %. (% V. out V. 1 %. 1800°. 3600°. Direction of Running (°)
34 THE VOUT ANALOG Single Output 99 % Output S1 supply 50 % (% V out V 1 % 1800° 3600° Direction of Running (°)
34 THE
www.vishay.com Vishay Spectrol
(output signal code: “A”)
99 % Output S1 ) supply 50 % (% V out V 1 % 0° 1800° 3600° Direction of Running (°) Redundant Output: with inverted slope
(output signal code: “G”)
99 % Output S1 ) supply 50 % (% V out V Output S2 1 % 0° 1800° 3600° Direction of Running (°) VOUT PWM Single Output:
(output signal code: “C”)
Vout (% V ) supply CW 97 % min. T high T Duty Cycle = high T T low 1.5 % max. 0 Time T: Periodicity VOUT SPI
Notice on demand Output signal code: “E” if CW (single or redundant identical) Output signal code: “F” if CCW (single or redundant identical) Output signal code: “K” if CW (if redundant but inverted slope) Revision: 25-Jul-12
2
Document Number: 57114 For technical questions, contact: sferprecisionpot@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
