34 THE www.vishay.com Vishay Spectrol MECHANICAL SPECIFICATIONSPARAMETERSTANDARDSPECIAL Servo mounting type or bushing mount Mounting type (delivered with nut and washer) Housing Anodized aluminum Shaft guiding 2 ball bearings for servo and sleeve bearing for bushing Shaft Stainless steel Ø 3.175 Other on request Outputs Turrets Other on request Mechanical travel 3600° and no stop ENVIRONMENTAL SPECIFICATIONS Operating temperature range - 40 °C; + 85 °C > 10M of cycles for bushing Life > 50M of cycles for servo Rotational speed (max.) 1200 rpm Immunity to radiated electromagnetic disturbances 200 V/m 150 kHz/1 GHz, IEC 62132-2 part 2 (level A) Immunity to power frequency magnetic field 200 A/m 50 Hz/60 Hz, EN 61000-4-8 (level A) Radiated electromagnetic emissions 30 MHz/1 GHz < 30 dBμV/m, EN 61000-6-4 (level A) Contact discharges: ± 4 kV Electrostatic discharges Air discharges: ± 8 kV, EN 61000-4-2 Sine vibration on 3 axes 1.5 mm or 20 g from 10 Hz to 2000 Hz Mechanical shocks on 3 axes 50 g, 11 ms, half sine Revision: 25-Jul-12 3 Document Number: 57114 For technical questions, contact: sferprecisionpot@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
