Datasheet AX-1838HS (Aixin) - 3
ManufacturerAixin
DescriptionMiniaturized infrared receivers for remote control and other applications requiring improved ambient light rejection in TSOP-style metal shield package
Pages / Page6 / 3 — aixin opto-electrical technology co.,ltd. AX-1838HS. Electrical And …
File Format / SizePDF / 418 Kb
aixin opto-electrical technology co.,ltd. AX-1838HS. Electrical And Optical Characteristics. Ratings. Parameter. Symbol. Unit
aixin opto-electrical technology co.,ltd AX-1838HS Electrical And Optical Characteristics Ratings Parameter Symbol Unit
(Ta=25℃)
Ratings Parameter Symbol Unit Condition Min. Typ. Max.
Supply Voltage Vs 2.1 - 5.5 V Supply Current Icc ¡ ¡ 1.5 mA No signal input L0 17 ¡ ¡ Reception Distance m At the ray axis*1 L45 8 ¡ ¡ B.P.F Center Frequency fo ¡ 38 ¡ KHz Peak Wavelength p ¡ 940 ¡ nm Half Angle  ¡ 45 ¡ deg At the ray axis *1 High Level Pulse Width TH 400 ¡ 800 S At the ray axis *2 Low Level Pulse Width TL 400 ¡ 800 S High Level Output Voltage VH 4.5 ¡ ¡ V Low Level Output Voltage VL ¡ ¡ 0.5 V *1:The ray receiving surface at a vertex and relation to the ray axis in the range of θ=0° and θ=45° *2:A range from 30cm to the arrival distance. Average value of 50 pulses ●
BLOCK DIAGRAM
Vcc Vout Preamp Amp Limiter B.P.F Demodulator Integrator Comparator PD ABLC GND Rev: 1.0Page: 2of 5
