Datasheet FDN360P (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionPowerTrench Single P-Channel MOSFET in SOT−23 package
Pages / Page6 / 2 — FDN360P. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. …
File Format / SizePDF / 290 Kb
FDN360P. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
FDN360P ELECTRICAL CHARACTERISTICS Symbol Parameter Test Conditions Min Typ Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
link to page 2 link to page 2 link to page 2
(TA = 25°C unless otherwise noted)
BVDSS Drain−Source Breakdown Voltage VGS = 0 V, ID = −250 mA −30 − − V DBV Breakdown Voltage Temperature Coefficient I DSS D = −250 mA, Referenced to 25_C − −22 − mV/_C DTJ IDSS Zero Gate Voltage Drain Current VDS = −24 V, VGS = 0 V − − −1 mA VDS = −24 V, VGS = 0 V, TJ = 55_C − − −10 IGSSF Gate−Body Leakage, Forward VGS = 20 V, VDS = 0 V − − 100 nA IGSSR Gate−Body Leakage, Reverse VGS = −20 V, VDS = 0 V − − −100 nA
ON CHARACTERISTICS
(Note 2) VGS(th) Gate Threshold Voltage VDS = VGS, ID = −250 mA −1 −1.9 −3 V DV Gate Threshold Voltage Temperature Coefficient I GS(th) D = −250 mA, Referenced to 25_C − 4 − mV/_C DTJ RDS(on) Static Drain−Source On−Resistance VGS = −10 V, ID = −2 A − 63 80 mW VGS = −10 V, ID = −2 A, TJ = 125_C − 90 136 VGS = −4.5 V, ID = −1.5 A − 100 125 ID(on) On−State Drain Current VGS = −10 V, VDS = −5 V −10 − − A gFS Forward Transconductance VDS = −5 V, ID = −2 A − 5 − S
DYNAMIC CHARACTERISTICS
Ciss Input Capacitance VDS = −15 V, VGS = 0 V, f = 1.0 MHz − 298 − pF Coss Output Capacitance − 83 − pF Crss Reverse Transfer Capacitance − 39 − pF
SWITCHING CHARACTERISTICS
(Note 2) td(on) Turn−On Delay Time VDD = −15 V, ID = −1 A, − 6 12 ns VGS = −10 V, RGEN = 6 W tr Turn−On Rise Time − 13 23 ns td(off) Turn−Off Delay Time − 11 20 ns tf Turn−Off Fall Time − 6 12 ns Qg Total Gate Charge VDS = −15 V, ID = −3.6 A, − 6.2 9 nC VGS = −10 V Qgs Gate−Source Charge − 1 − nC Qgd Gate−Drain Charge − 1.2 − nC
DRAIN−SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
IS Maximum Continuous Drain−Source Diode Forward Current − − −0.42 A VSD Drain−Source Diode Forward Voltage VGS = 0 V, IS = −0.42 A (Note 2) − −0.8 −1.2 V Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. NOTES: 1. RθJA is the sum of the junction−to−case and case−to−ambient thermal resistance where the case thermal reference is defined as the solder mounting surface of the drain pins. RθJC is guaranteed by design while RθCA is determined by the user’s board design. a) 250°C/W when mounted on b) 270°C/W when mounted on a 0.02 in2 pad of 2 oz copper a minimum pad Scale 1:1 on letter size paper 2. Pulse Test: Pulse Width ≤ 300 μs, Duty Cycle ≤ 2.0%.
www.onsemi.com 2
