Datasheet UU10LF (Sumida)
ManufacturerSumida
DescriptionAC Common Mode Coil in Vertical, 4 PC Pin package
Pages / Page2 / 1 — Product Description. Feature. Dimensions (mm). UU10LF. UU10LFB. …
File Format / SizePDF / 146 Kb
Product Description. Feature. Dimensions (mm). UU10LF. UU10LFB. www.sumida.com
Datasheet UU10LF Sumida
AC COMMON MODE COIL <Pin Type: UU Series> Type: UU10LF, UU10LFB ◆
Product Description
・18.5×17.0mm Max.(L×W), 23.0mm Max. Height. ・Inductance range: 3.3mH~51mH ・Rated current range: 0.15~0.65A ・In addition to the standard versions of parameters shown here, custom designs are available to meet your exact requirements. ◆
Feature
・Ideally used as AC common mode noise filter for TV, VCR, Switching power supply, NC machine, PC&PC related advice, measurement and control unit. ・UU10LFB has better high frequency characteristics for its split bobbin structure. ・RoHS Compliance ◆
Dimensions (mm)
17.0 MAX. 23.0 MAX. 5.7 MAX. 4.0±1.0 10.0±0.3 3 2 MAX. ±0. ±0. .5
UU10LF
18 0.7 13.0 φ 17.0 MAX. 23.0 MAX. 4.0±1.0 10.0±0.3 5.7 MAX. 2 3 . MAX. 5
UU10LFB
.7±0 .0±0 18. 13 φ0 * Dimension does not include solder used on coil. * Terminal pitch is measured at the base.(not from tip of the pin) Please refer to the sales offices on our website for a representative near you
www.sumida.com
1/2
