Datasheet MC33039, NCV33039 (ON Semiconductor) - 5
ManufacturerON Semiconductor
DescriptionHigh performance closed-loop speed control adapter for use in brushless DC motor control systems
Pages / Page11 / 5 — MC33039, NCV33039. Figure 3. fout, Pulse Width. Figure 4. fout, Pulse …
File Format / SizePDF / 362 Kb
MC33039, NCV33039. Figure 3. fout, Pulse Width. Figure 4. fout, Pulse Width Change. versus Timing Resistor. versus Temperature
MC33039, NCV33039 Figure 3 fout, Pulse Width Figure 4 fout, Pulse Width Change versus Timing Resistor versus Temperature
MC33039, NCV33039
100 +1.6 V V CC = 6.25 V CC = 6.25 V T R A = 25C T = 10 k 10 +0.8 CT = 22 nF CT = 220 nF 1.0 0 PULSE WIDTH (ms) CT = 22 nF PULSE WIDTH CHANGE (%) 0.1 -0.8 , OUTPUT , OUTPUT CT = 2.2 nF t PW t PW  0.01 -1.6 2.0 20 200 - 55 - 25 0 + 25 + 50 + 75 + 100 + 125 R T T , TIMING RESISTOR (kW) A , AMBIENT TEMPERATURE (C)
Figure 3. fout, Pulse Width Figure 4. fout, Pulse Width Change versus Timing Resistor versus Temperature
+ 4.0 20 Pins 1, 2, 3 TA = 25C Connected 16 together + 2.0 (mA) 12 0 CURRENT Y PULSE WIDTH CHANGE (%) 8.0 , SUPPL - 2.0 I CC T , OUTPUT 4.0 A = -40C t PW  TA = 25C T - 4.0 0 A = 125C 4.5 5.5 6.5 7.5 8.5 0 2.0 4.0 6.0 8.0 10 V V CC , SUPPLY VOLTAGE (V) CC , SUPPLY VOLTAGE (V)
Figure 5. fout, Pulse Width Change Figure 6. Supply Current versus versus Supply Voltage Supply Voltage
+ 0.6 0 V +16 CC = 6.25 V VCC T V TAGE (V) A = 25C CC = 6.25 V + 0.4 - 2.0 IO = 5.0 mA TION CHANGE (%) Source Saturation +8.0 (Load to Ground) TION CHANGE (%) TURA TION VOL - 4.0 + 0.2 TURA D Sink Saturation D TURA Source Saturation 0 (Load to VCC) (Load to Ground) SA + 0.4 0 , SOURCE SA Sink Saturation , SINK SA - 8.0 + 0.2 (Load to VCC) , OUTPUT - 0.2 sat GND sat (sink) V V 0 -16  sat (SOURCE) 0 4.0 8.0 12 16 - 55 - 25 0 + 25 + 50 + 75 + 100 + 125 V  IO , OUTPUT LOAD CURRENT (mA) TA , AMBIENT TEMPERATURE (C)
Figure 7. fout, Saturation Figure 8. fout, Saturation Change versus Load Current versus Temperature www.onsemi.com Share Feedback 5
Your Opinion Matters
