Datasheet 74AVC2T45FK (Toshiba)
| Manufacturer | Toshiba |
| Description | 2-Bit Dual-Supply Bus Transceiver with Configurable Power Supply in SOT-765 (US8) package |
| Pages / Page | 17 / 1 — 74AVC2T45FK. CMOS. Digital. Integrated. Circuits. Silicon. Monolithic. … |
| File Format / Size | PDF / 313 Kb |
74AVC2T45FK. CMOS. Digital. Integrated. Circuits. Silicon. Monolithic. 74AVC2T45FK. 1. Functional. Description. •. 2-Bit. Dual-Supply. Bus
74AVC2T45FK CMOS Digital Integrated Circuits Silicon Monolithic 74AVC2T45FK 1. Functional Description • 2-Bit Dual-Supply Bus Transceiver with Configurable Power Supply 2. General The 74AVC2T45FK is a dual-supply, high-speed CMOS 2-bit bus transceiver that can interface between two systems with supply voltages from 0.8 V to 3.6 V. The two supply voltages can be user-configurable within the operating range and the sequence of supply voltage ON/OFF can be freely set. When the transmission direction switching input DIR is set to "H", bus A becomes an input and bus B becomes an output, and when set to "L", bus A becomes an output and bus B becomes an input.The input (DIR) has a tolerant function that allows input of up to 3.6 V regardless of the supply voltage. When either power supply is at the GND level, the bus terminals are placed in a high impedance mode and a voltage of up to 3.6 V is allowed to be applied. This feature allows for partial power-down interface applications. All inputs are equipped with protection circuits to protect the devices from electrostatic discharge damage. 3. Features (1) Wide operating temperature range: Topr = -40 to 125 � (2) Wide supply voltage value: VCCA = 0.8 to 3.6 V, VCCB = 0.8 to 3.6 V (3) Bidirectional interface (4) High-speed operation: tpd = 4.1 ns (max) (VCCA = 3.3 ± 0.3 V, VCCB = 3.3 ± 0.3 V) (5) Output current: |IOH|/IOL = ± 12 mA (min) (VCC = 3.0 V) |IOH|/IOL = ± 9 mA (min) (VCC = 2.3 V) |IOH|/IOL = ± 6 mA (min) (VCC = 1.65 V) |IOH|/IOL = ± 4 mA (min) (VCC = 1.4 V) |IOH|/IOL = ± 2 mA (min) (VCC = 1.1 V) (6) Small package: US8 (Package code: SOT-765) (7) Low power dissipation: Suitable for battery-driven applications such as PDAs and cellular phones. (8) 3.6 V tolerance and power-down protection are provided to all inputs and outputs. 4. Packaging US8 Start of commercial production 2025-08 ©2026 1 Toshiba Electronic Devices & Storage Corporation 2026-04-21 Rev.2.0.A
