Not for New Designs 1N5615GP, 1N5617GP, 1N5619GP, 1N5621GP, 1N5623GP www.vishay.com Vishay General Semiconductor Glass Passivated Junction Fast Switching Plastic Rectifier FEATURES • Superectifier structure for high reliability condition • Cavity-free glass-passivated junction SUPERECTIFIER® • Fast switching for high efficiency • Low leakage current • High forward surge capability • Solder dip 275 °C max. 10 s, per JESD 22-B106 • Material categorization: for definitions of compliance DO-15 (DO-204AC) please see www.vishay.com/doc?99912 TYPICAL APPLICATIONS For use in fast switching rectification of power supply, PRIMARY CHARACTERISTICS inverters, converters and freewheeling diodes for consumer IF(AV) 1.0 A and telecommunication. VRRM 200 V, 400 V, 600 V, 800 V, 1000 V IFSM 50 A MECHANICAL DATA trr 150 ns, 250 ns, 300 ns, 500 ns Case: DO-15 (DO-204AC), molded epoxy over glass body IR 0.5 μA Molding compound meets UL 94 V-0 flammability rating Base P/N-E3 - RoHS-compliant, commercial grade VF 1.2 V Terminals: matte tin plated leads, solderable per TJ max. 175 °C J-STD-002 and JESD 22-B102 Package DO-15 (DO-204AC) E3 suffix meets JESD 201 class 1A whisker test Circuit configuration Single Polarity: color band denotes cathode end MAXIMUM RATINGS (TA = 25 °C unless otherwise noted) PARAMETER SYMBOL 1N5615GP 1N5617GP 1N5619GP 1N5621GP 1N5623GP UNIT Maximum repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Maximum RMS voltage VRMS 140 280 420 560 700 V Maximum DC blocking voltage VDC 200 400 600 800 1000 A Maximum average forward rectified current I 0.375" (9.5 mm) lead length at T F(AV) 1.0 A A = 55 °C Peak forward surge current 8.3 ms single half I sine-wave superimposed on rated load FSM 50 A Operating junction and T storage temperature range J, TSTG -65 to +175 °C Revision: 05-Oct-2021 1 Document Number: 88522 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
