Datasheet BA157, BA158, BA159D, BA159 (Vishay)
ManufacturerVishay
DescriptionFast Switching Plastic Rectifier 400V, 1A in DO-41 (DO-204AL) package
Pages / Page4 / 1 — BA157, BA158, BA159D, BA159. Fast Switching Plastic Rectifier. FEATURES. …
File Format / SizePDF / 69 Kb
BA157, BA158, BA159D, BA159. Fast Switching Plastic Rectifier. FEATURES. DO-41 (DO-204AL). TYPICAL APPLICATIONS
Datasheet BA157, BA158, BA159D, BA159 Vishay
www.vishay.com Vishay General Semiconductor
Fast Switching Plastic Rectifier FEATURES
• Fast switching for high efficiency • Low forward voltage drop • Low leakage current • High forward surge capability • Solder dip 275 °C max. 10 s, per JESD 22-B106
DO-41 (DO-204AL)
• Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
For use in fast switching rectification of power supply, inverters, converters and freewheeling diodes for consumer
PRIMARY CHARACTERISTICS
and telecommunication. IF(AV) 1.0 A V
MECHANICAL DATA
RRM 400 V, 600 V, 800 V, 1000 V IFSM 20 A
Case:
DO-41 (DO-204AL), molded epoxy body t Molding compound meets UL 94 V-0 flammability rating rr 150 ns, 250 ns, 500 ns Base P/N-E3 - RoHS-compliant, commercial grade IR 5.0 μA V
Terminals:
matte tin plated leads, solderable per F 1.3 V J-STD-002 and JESD 22-B102 TJ max. 125 °C E3 suffix meets JESD 201 class 1A whisker test Package DO-41 (DO-204AL)
Polarity:
color band denotes cathode end Circuit configuration Single
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted)
PARAMETER SYMBOL BA157 BA158 BA159D BA159 UNIT
Maximum repetitive peak reverse voltage VRRM 400 600 800 1000 V Maximum RMS voltage VRMS 280 420 560 700 V Maximum DC blocking voltage VDC 400 600 800 1000 V Maximum average forward rectified current  I 0.375" (9.5 mm) lead length at T F(AV) 1.0 A A = 55 °C Peak forward surge current 10 ms single half sine-wave superimposed I on rated load FSM 20 A Maximum operation junction temperature TJ -65 to +125 °C Maximum storage temperature TSTG -65 to +150 °C
ELECTRICAL CHARACTERISTICS
PARAMETER TEST CONDITIONS SYMBOL BA157 BA158 BA159D BA159 UNIT
Maximum instantaneous 1.0 A V forward voltage F 1.3 V Maximum DC reverse current T at rated DC blocking voltage A = 25 °C IR 5.0 μA Maximum reverse recovery time IF = 0.5 A, IR = 1.0 A, Irr = 0.25 A trr 150 250 500 ns Typical junction capacitance 4.0 V, 1 MHz CJ 12 pF Revision: 01-Jul-2020
1
Document Number: 88536 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
