Datasheet DB107G (Unisonic Technologies) - 2
ManufacturerUnisonic Technologies
Description1.0A Glass Passivated Single-Phase Bridge Rectifier in DFM package
Pages / Page4 / 2 — DB107G. DIODE. ABSOLUTE MAXIMUM RATINGS. THERMAL CHARACTERISTICS (Note …
File Format / SizePDF / 219 Kb
DB107G. DIODE. ABSOLUTE MAXIMUM RATINGS. THERMAL CHARACTERISTICS (Note 2). ELECTRICAL CHARACTERISTICS
DB107G DIODE ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS (Note 2) ELECTRICAL CHARACTERISTICS
(TA=25°C unless otherwise noted) PARAMETER SYMBOL RATINGS UNIT Repetitive Peak Reverse Voltage VRRM 1000 V RMS Voltage VRMS 700 V Continuous Reverse Voltage VR 1000 V Forward Rectified Current I 0.06”(1.5mm) lead lenth at T O 1.0 A A=40°C (Note 2) Peak Forward Surge Current 8.3ms Single Half I Sine-Wave Superimposed on Rated Load FSM 50 A I2t Rating for Fusing t<8.3ms I2t 10 A2s Operating Temperature TJ -65~+150 °C Storage Temperature TSTG -65~+150 °C Note: Absolute maximum ratings are those values beyond which the device could be permanently damaged. Absolute maximum ratings are stress ratings only and functional device operation is not implied.
PARAMETER SYMBOL RATINGS UNIT Junction to Ambient θJA 40 °C/W
(TA=25°C unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Forward Voltage (t<8.3ms ) VF IF=1.0A 1.10 V DC Reverse Current at Rated DC Blocking V I R=VRRM, TA=25°C 10 μA Voltage R VR=VRRM, TA=100°C 500 μA Junction Capacitance Per Element (Note 1) CJ 25 pF Notes: 1. Measured at 1.0MHz and applied reverse voltage of 4.0V D.C. 2. Mounted on P.C.B with 0.51"×0.51"(13×13mm) copper pads.
UNISONIC TECHNOLOGIES CO., LTD
2 of 4
www.unisonic.com.tw
QW-R227-003.A
