Datasheet DML1012ALDSQ (Diodes)
ManufacturerDiodes
DescriptionSingle-Channel Smart Load Switch in V-DFN3030-8 (Type R) package
Pages / Page12 / 1 — DML1012ALDSQ. SINGLE-CHANNEL SMART LOAD SWITCH. Description. Features and …
File Format / SizePDF / 844 Kb
DML1012ALDSQ. SINGLE-CHANNEL SMART LOAD SWITCH. Description. Features and Benefits
Datasheet DML1012ALDSQ Diodes
DML1012ALDSQ SINGLE-CHANNEL SMART LOAD SWITCH Description Features and Benefits
The DML1012ALDSQ is a single-channel load switch with very low • Low RDS(ON) – Ensures On-State Losses Are Minimized on-resistance in a small package. It contains an n-channel MOSFET • 0.8V to VBIAS – 1.5V Input-Voltage Range for up to VBIAS – 1.5V input-voltage operation and 6A current channel • 6A Continuous Current with 3.2V to 5.5V bias supply. The load switch is controlled by a low- • Low RDS(ON) Internal nFETs voltage control signal through ON pin. 8mΩ at VBIAS = 5V, VIN = 1.05V, TA = +85°C • 28µA Low Quiescent Current • 20µs Turn-On Rise Time • 3.2V to 5.5V Bias Voltage • Integrated Quick Output Discharge Resistor •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
The DML1012ALDSQ is suitable for automotive applications requiring specific change control; this part is AEC-Q101 qualified, PPAP capable, and manufactured in IATF 16949 certified facilities. https://www.diodes.com/quality/product-definitions/ Applications Mechanical Data
• Automotive/industrial electronics • Package: V-DFN3030-8 • ADAS (advanced driver assistance systems) • Package Material: Molded Plastic, “Green” Molding Compound. • Infotainment UL Flammability Classification Rating 94V-0 • Moisture Sensitivity: Level 3 per J-STD-020 • Terminals: Finish — NiPdAu over Copper Leadframe. Solderable per MIL-STD-202, Method 208
e4
• Weight: 0.022 grams (Approximate) V-DFN3030-8 (Type R) Pin 1 Top View Bottom View Top View Bottom View
Ordering Information
(Note 4)
Packing Orderable Part Number Package Tape Width Tape Pitch Qty. Carrier
DML1012ALDSQ-7A V-DFN3030-8 (Type R) 12mm 8mm 1,500 Tape & Reel DML1012ALDSQ-13 V-DFN3030-8 (Type R) 12mm 8mm 3,000 Tape & Reel Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/. DML1012ALDSQ 1 of 12 April 2026 Document number: DS46286 Rev. 2 - 2
www.diodes.com
© 2026 Copyright Diodes Incorporated. All Rights Reserved.
