Datasheet DML1012ALDSQ (Diodes) - 3
| Manufacturer | Diodes |
| Description | Single-Channel Smart Load Switch in V-DFN3030-8 (Type R) package |
| Pages / Page | 12 / 3 — DML1012ALDSQ. Pin Description. Pin Number. Pin Name. Pin Function. … |
| File Format / Size | PDF / 844 Kb |
DML1012ALDSQ. Pin Description. Pin Number. Pin Name. Pin Function. Functional Block Diagram. www.diodes.com
DML1012ALDSQ Pin Description Pin Number Pin Name Pin Function
1, 2, EPAD IN Load Switch Input. Bypass capacitor is recommended to minimize input-voltage dip. 3 VBIAS Bias Voltage. Power-supply input for the device. Enable Input. Load switch is on when ON is pulled high. Load switch is off when ON is pulled low. 4 ON Do not leave floating. 5 GND Ground. 6, 7, 8 OUT Load Switch Output.
1 8 IN OUT 2 7 IN OUT 3 6 VBIAS OUT 4 5 ON Control GND Logic DML1012ALDSQ 3 of 12 April 2026 Document number: DS46286 Rev. 2 - 2
www.diodes.com
© 2026 Copyright Diodes Incorporated. All Rights Reserved.
