Datasheet TZX (Vishay) - 2
| Manufacturer | Vishay |
| Description | Small Signal Zener Diodes in DO-35 (DO-204AH) package |
| Pages / Page | 7 / 2 — TZX-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. DYNAMIC. TEST … |
| File Format / Size | PDF / 125 Kb |
TZX-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. DYNAMIC. TEST CURRENT. REVERSE LEAKAGE CURRENT. RANGE. RESISTANCE. PART NUMBER
TZX-Series
(Tamb = 25 °C, unless otherwise specified)
ZENER VOLTAGE DYNAMIC TEST CURRENT REVERSE LEAKAGE CURRENT RANGE RESISTANCE PART NUMBER VZ at IZT1 IZT1 IR at VR IR at VR (1) ZZ at IZT1 V mA μA V μA V
Ω
MIN. MAX. MAX. MAX. MAX.
TZX2V4A 2.3 2.5 5 5 0.5 50 1 100 TZX2V4B 2.4 2.6 5 5 0.5 50 1 100 TZX2V7A 2.5 2.7 5 5 0.5 10 1 100 TZX2V7B 2.6 2.8 5 5 0.5 10 1 100 TZX2V7C 2.7 2.9 5 5 0.5 10 1 100 TZX3V0A 2.8 3 5 5 0.5 6 1 100 TZX3V0B 2.9 3.1 5 5 0.5 6 1 100 TZX3V0C 3 3.2 5 5 0.5 6 1 100 TZX3V3A 3.1 3.3 5 5 1 2 1 100 TZX3V3B 3.2 3.4 5 5 1 2 1 100 TZX3V3C 3.3 3.5 5 5 1 2 1 100 TZX3V6A 3.4 3.6 5 5 1 2 1 100 TZX3V6B 3.5 3.7 5 5 1 2 1 100 TZX3V6C 3.6 3.8 5 5 1 2 1 100 TZX3V9A 3.7 3.9 5 5 1 2 1 100 TZX3V9B 3.8 4 5 5 1 2 1 100 TZX3V9C 3.9 4.1 5 5 1 2 1 100 TZX4V3A 4 4.2 5 5 1.5 1 1 100 TZX4V3B 4.1 4.3 5 5 1.5 1 1 100 TZX4V3C 4.2 4.4 5 5 1.5 1 1 100 TZX4V3D 4.3 4.5 5 5 1.5 1 1 100 TZX4V7A 4.4 4.6 5 5 2 6 2 100 TZX4V7B 4.5 4.7 5 5 2 5 2 100 TZX4V7C 4.6 4.8 5 5 2 4 2 100 TZX4V7D 4.7 4.9 5 5 2 3 2 100 TZX5V1A 4.8 5 5 5 2 2 2 100 TZX5V1B 4.9 5.1 5 5 2 2 2 100 TZX5V1C 5 5.2 5 5 2 2 2 100 TZX5V1D 5.1 5.3 5 5 2 2 2 100 TZX5V6A 5.2 5.5 5 5 2 1 2 40 TZX5V6B 5.3 5.6 5 5 2 1 2 40 TZX5V6C 5.4 5.7 5 5 2 1 2 40 TZX5V6D 5.5 5.8 5 5 2 1 2 40 TZX5V6E 5.6 5.9 5 5 2 1 2 40 TZX6V2A 5.7 6 5 1 3 3 4 15 TZX6V2B 5.8 6.1 5 1 3 3 4 15 TZX6V2C 6 6.3 5 1 3 3 4 15 TZX6V2D 6.1 6.4 5 1 3 3 4 15 TZX6V2E 6.3 6.6 5 1 3 3 4 15 TZX6V8A 6.4 6.7 5 1 3.5 2 4 15 TZX6V8B 6.6 6.9 5 1 3.5 2 4 15 TZX6V8C 6.7 7 5 1 3.5 2 4 15 TZX6V8D 6.9 7.2 5 1 3.5 2 4 15 Rev. 2.7, 04-Jun-2024
2
Document Number: 85614 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
