Datasheet LTC7897 (Analog Devices) - 3
Description140V, Low IQ, Synchronous Buck Controller with Programmable 5V to 10V Gate Drive in 28-Lead QFN (4mm x 5mm x 0.75mm w/ EP) package
Pages / Page53 / 3 — Data Sheet. LTC7897. REVISION HISTORY. REVISION. DESCRIPTION. PAGE. …
Data Sheet. LTC7897. REVISION HISTORY. REVISION. DESCRIPTION. PAGE. NUMBER. DATE. analog.com
Data Sheet LTC7897 REVISION HISTORY REVISION DESCRIPTION PAGE NUMBER DATE analog.com
link to page 32 link to page 32 link to page 33 link to page 34 link to page 35 link to page 37 link to page 38 link to page 38 link to page 38 link to page 38 link to page 38 link to page 39 link to page 40 link to page 41 link to page 42 link to page 43 link to page 44 link to page 50 link to page 51 link to page 52
Data Sheet LTC7897
CIN and COUT Selection ... 32 Setting the Output Voltage .. 32 RUN Pin and Overvoltage/Undervoltage Lockout ... 33 Soft-Start and Tracking (TRACK/SS Pin) ... 34 DRVCC and INTVCC Regulators (OPTI-DRIVE) ... 35 Topside MOSFET Driver Supply (CB, DB) ... 37 Minimum On-Time Considerations ... 38 Fault Conditions: Current Limit and Foldback ... 38 Fault Conditions: Overvoltage Protection .. 38 Fault Conditions: Overtemperature Protection ... 38 Phase-Locked Loop and Frequency Synchronization ... 38 Efficiency Considerations ... 39 Checking Transient Response ... 40 Design Example .. 41 PC Board Layout Checklist ... 42 PC Board Layout Debugging .. 43 Typical Application .. 44 Related Parts .. 50 Outline Dimensions ... 51 Ordering Guide ... 52
REVISION HISTORY REVISION REVISION DESCRIPTION PAGE NUMBER DATE NUMBER
0 2/25 Initial release — A 7/25 Updated Features and General Description sections 1 Updated Specifications and Absolute Maximum Ratings sections 4‒9 Updated Pin Descriptions table 11, 12 Updated Figure 4, Figure 23, Figure 25, and Figure 30 14, 18, 19 Updated DRVCC and INTVCC Regulators (OPTI-DRIVE) section 35, 37 Updated Minimum On-Time Considerations section 38 Updated Efficiency Considerations section 40 Updated Figure 54 and Figure 58 46, 48
analog.com
Rev. A 3 of 53 Document Outline Features Applications General Description Typical Application TABLE OF CONTENTS Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Block Diagram Typical Performance Characteristics Theory of Operation Main Control Loop Power and Bias Supplies (VIN, EXTVCC, DRVCC, and INTVCC) High-Side Bootstrap Capacitor Dead Time Control (DTCA and DTCB Pins) Start-Up and Shutdown (RUN, OVLO, and TRACK/SS Pins) Light Load Operation: Burst Mode Operation, Pulse-Skipping Mode, or Forced Continuous Mode (MODE Pin) Frequency Selection, Spread Spectrum, and PhaseLocked Loop (FREQ and PLLIN/SPREAD Pins) Input Supply Overvoltage Lockout (OVLO Pin) Output Overvoltage Protection Foldback Current Power Good Applications Information Inductor Value Calculation Inductor Core Selection Current Sense Selection Low Value Resistor Current Sensing Inductor DCR Current Sensing Setting the Operating Frequency Selecting the Light-Load Operating Mode Dead Time Control (DTCA and DTCB Pins) DTCX Pins Tied to INTVCC or Ground (Adaptive Dead Time Control) DTCX Pin Connected with a Resistor to GND Power MOSFET Selection CIN and COUT Selection Setting the Output Voltage RUN Pin and Overvoltage/Undervoltage Lockout Soft-Start and Tracking (TRACK/SS Pin) DRVCC and INTVCC Regulators (OPTI-DRIVE) Topside MOSFET Driver Supply (CB, DB) Minimum On-Time Considerations Fault Conditions: Current Limit and Foldback Fault Conditions: Overvoltage Protection Fault Conditions: Overtemperature Protection Phase-Locked Loop and Frequency Synchronization Efficiency Considerations Checking Transient Response Design Example PC Board Layout Checklist PC Board Layout Debugging Typical Application Related Parts Outline Dimensions Ordering Guide
