Datasheet LTC7897 (Analog Devices) - 8
Description140V, Low IQ, Synchronous Buck Controller with Programmable 5V to 10V Gate Drive in 28-Lead QFN (4mm x 5mm x 0.75mm w/ EP) package
Pages / Page53 / 8 — Data Sheet. LTC7897. PARAMETER. SYMBOL. CONDITIONS/COMMENTS. MIN. TYP. …
Data Sheet. LTC7897. PARAMETER. SYMBOL. CONDITIONS/COMMENTS. MIN. TYP. MAX. UNITS. analog.com
Data Sheet LTC7897 PARAMETER SYMBOL CONDITIONS/COMMENTS MIN TYP MAX UNITS analog.com
link to page 26 link to page 38
Data Sheet LTC7897
(Specifications are for TJ = -40°C to +150°C for the minimum and maximum values, TA = 25°C for the typical values, VIN = 12V, RUN = 12V, VPRG = floating, EXTVCC = 0V, DRVSET = 0V, DRVUV = 0V, TGUP = TGDN = TGxx, BGUP = BGDN = BGxx, and DTCA and DTCB = 0V, unless otherwise noted.)
PGOOD Delay for 25 Reporting a Fault μs .1 This specification is not tested in production. 2 The LTC7897 is tested in a feedback loop that servos VITH to a specified voltage and measures the resultant VFB. 3 SENSE− bias current is reflected to the input supply by the formula IVIN = ISENSE− × VOUT/(VIN × η), where η is the efficiency. 4 Rise and fall times are measured using 10% and 90% levels. Delay times are measured using 50% levels. 5 SW falling to BGxx rising and BGxx falling to SW rising delay times are measured at rising/falling thresholds on SW and BGxx of approximately 1.5V. See Figure 36. 6 The minimum on-time condition specified for inductor peak-to-peak ripple current is >40% of the maximum load current (IMAX) (see the Minimum On-Time Considerations section).
analog.com
Rev. A 8 of 53 Document Outline Features Applications General Description Typical Application TABLE OF CONTENTS Revision History Specifications Absolute Maximum Ratings Pin Configurations and Function Descriptions Block Diagram Typical Performance Characteristics Theory of Operation Main Control Loop Power and Bias Supplies (VIN, EXTVCC, DRVCC, and INTVCC) High-Side Bootstrap Capacitor Dead Time Control (DTCA and DTCB Pins) Start-Up and Shutdown (RUN, OVLO, and TRACK/SS Pins) Light Load Operation: Burst Mode Operation, Pulse-Skipping Mode, or Forced Continuous Mode (MODE Pin) Frequency Selection, Spread Spectrum, and PhaseLocked Loop (FREQ and PLLIN/SPREAD Pins) Input Supply Overvoltage Lockout (OVLO Pin) Output Overvoltage Protection Foldback Current Power Good Applications Information Inductor Value Calculation Inductor Core Selection Current Sense Selection Low Value Resistor Current Sensing Inductor DCR Current Sensing Setting the Operating Frequency Selecting the Light-Load Operating Mode Dead Time Control (DTCA and DTCB Pins) DTCX Pins Tied to INTVCC or Ground (Adaptive Dead Time Control) DTCX Pin Connected with a Resistor to GND Power MOSFET Selection CIN and COUT Selection Setting the Output Voltage RUN Pin and Overvoltage/Undervoltage Lockout Soft-Start and Tracking (TRACK/SS Pin) DRVCC and INTVCC Regulators (OPTI-DRIVE) Topside MOSFET Driver Supply (CB, DB) Minimum On-Time Considerations Fault Conditions: Current Limit and Foldback Fault Conditions: Overvoltage Protection Fault Conditions: Overtemperature Protection Phase-Locked Loop and Frequency Synchronization Efficiency Considerations Checking Transient Response Design Example PC Board Layout Checklist PC Board Layout Debugging Typical Application Related Parts Outline Dimensions Ordering Guide
