Datasheet VS-HOT200C080 (Vishay) - 3
ManufacturerVishay
DescriptionFlatPAK HC0 Transfer Mold Power Module Half Bridge - Power MOSFET, 200 A in FlatPAK HC0 package
Pages / Page12 / 3 — VS-HOT200C080. SOURCE-DRAIN ELECTRICAL CHARACTERISTICS. PARAMETER SYMBOL. …
File Format / SizePDF / 203 Kb
VS-HOT200C080. SOURCE-DRAIN ELECTRICAL CHARACTERISTICS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. TYP. MAX. UNITS
VS-HOT200C080 SOURCE-DRAIN ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS
VS-HOT200C080
(TJ = 25 °C unless otherwise specified)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNITS
Diode forward voltage VSD ISD = 200 A, VGS = 0 V - 0.83 1 V Reverse recovery time trr - 106 - ns Reverse recovery charge Qrr I - 7180 - nC SD = 250 A, dI/dt = 2400 A/μs, V Reverse recovery current I R = 52 V RM - 107 - A Reverse recovery energy Erec - 0.3 - mJ Reverse recovery time trr - 100 - ns Reverse recovery charge Qrr T - 6668 - nC J = 125 °C, ISD = 250 A, dI/dt = 2400 A/μs, V Reverse recovery current I R = 52 V RM - 107 - A Reverse recovery energy Erec - 0.263 - mJ
INTERNAL NTC - THERMISTOR SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS VALUE UNITS
Resistance R25 T = 25 °C 10 000 Ω B-value B25/100 R2 = R25 exp. [B25/100(1/T2 - 1/(298.15K))] 3625 ± 1 % K Operating temperature range at zero power -40 to +150 °C Dissipation factor D 3.0 mW/K Thermal time constant τ < 4 s
INTERNAL POWER METAL STRIP RESISTOR - ELECTRICAL SPECIFICATION POWER RATING (W) P70 °C VALUE (
Ω
) TOLERANCE (%)
8.0 0.0003 ± 1.0
INTERNAL POWER METAL STRIP RESISTOR - TECHNICAL SPECIFICATION PARAMETER UNIT RESISTOR CHARACTERISTICS
Component temperature coefficient (including terminal) (1) ppm/K < 35 Operating temperature range °C -65 to 170
Note
(1) Component TCR - total TCR that includes the TCR effects of the resistor element and the copper terminal
INTERNAL CAPACITORS - ELECTRICAL SPECIFICATIONS PARAMETER SYMBOL VALUE TOLERANCE (%) UNITS
Capacitance C 68 ± 10 nF Voltage V 100 - V Operating temperature range Top -55 to +150 - °C Revision: 27-Jan-2026
3
Document Number: 97360 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
