Datasheet E10561-J-WH-0-WF (Toyo LED) - 7
ManufacturerToyo LED
DescriptionWhite 0.56" Seven Segment Display Cathode LED
Pages / Page8 / 7 — TOYO LED ELECTRONICS LIMITED. P/N: E10561-J-WH-0-WF. PACKING & LABEL …
File Format / SizePDF / 222 Kb
TOYO LED ELECTRONICS LIMITED. P/N: E10561-J-WH-0-WF. PACKING & LABEL SPECIFICATIONS. Electrostatic Discharge(ESD). Other
TOYO LED ELECTRONICS LIMITED P/N: E10561-J-WH-0-WF PACKING & LABEL SPECIFICATIONS Electrostatic Discharge(ESD) Other
Room 1610, Hong Kong Plaza, 188 Connaught Road West, Hong Kong. Tel : (852) 2540 7288 Fax : (852) 2517 1797 http://www.toyo-led.com E-mail : sales@toyo-led.com
1. LEDs can be damaged by electrostatic discharge or surge current (EOS). 2. An ESD wrist strap,ESD shoe strap or antistatic gloves must be worn whenever handling LEDs. 3. Grounded properly must be applied for all devices,equipment and machinery. 4. Use ion blower to neutralize the static charge which might have built up on surface of the LEDs plastic lens as a result of friction between LEDs during storage and handing.
Other
1 Above specification may be changed without notice. TOYO will reserve authority on material change for above specification. 2 When using this product, please abserve the absolute maximum ratings and the instructions for using outlined in these specification sheets. TOYO assumes no responsibility for any damage resulting from use of the product which does not comply with the absolute maximum ratings and the instructions included in these specification sheets. 3 These specification sheets include materials protected under copyright of TOYO LED ELECTRONICS LIMITED. Please don’t reproduce cause by anyone to reproduce them without TOYO’s consent. Notes: 1. All dimension are in millimeter; 2. Tolerance is ±0.25mm unless otherwise specified. 3. Not recommend to solder within 3mm from the resin. TOYO LED ELECTRONICS LIMITED Page 7 of 8
