Datasheet XC8115, XC8116 (Torex) - 6
ManufacturerTorex
Description6V, 1A Ultra-Low Power Load Switch IC
Pages / Page27 / 6 — XC8115/XC8116. Series
XC8115/XC8116 Series
■ ABSOLUTE MAXIMUM RATINGS Ta=25°C PARAMETER SYMBOL RATING UNIT VIN Pin Voltage VIN -0.3 ~ 6.6 V VOUT Pin Voltage VOUT -0.3 ~ 6.6 V EN/ENB Pin Voltage VEN/ENB -0.3 ~ 6.6 V CSS Pin Voltage VCSS -0.3 ~ 6.6 V VOUT Pin Current IOUT 2.0 A DFN1515-6A 1000 (JESD51-7 board) (*1) mW Power Dissipation Pd SOT-25 950 (JESD51-7 board) (*1) mW Junction Temperature Tj -40 ~ 150 ℃ Storage Temperature Tstg -55 ~ 150 °C Al voltages are based on the VSS. (*1) The power dissipation figure shown is PCB mounted and is for reference only. Please refer to PACKAGING INFORMATION for the mounting conditions. ■ Recommended Operating Conditions PARAMETER SYMBOL MIN. TYP. MAX. UNIT Applied voltage to VOUT : 1.1 - 6.0 0V ~ 1.1V Input Voltage VIN V Applied voltage to VOUT : 0.0 - 6.0 1.1V ~ 6.0V Applied voltage to VIN : 1.1 - 6.0 0V ~ 1.1V Output Voltage VOUT V Applied voltage to VIN : 0.0 - 6.0 1.1V ~ 6.0V Output Current IOUT - - 1.0 A EN/ENB Pin Voltage VEN/ENB 0.0 - 6.0 V Operating Ambient Temperature Topr -40 - 105 °C Junction Temperature Tj -40 - 125 °C Css Capacitor (Effective Value) Css Open - Any μF Input Capacitor (Effective Value) (*1) CIN Open - Any μF Output Capacitor (Effective Value) (*2) CL Open - Any μF Al voltages are based on the VSS. (*1) The XC8115/XC8116 series does not require an input capacitor (CIN) for normal operation. However, it is recommended to connect a ceramic capacitor of 0.01 µF or greater as close to VIN pin as possible to prevent malfunctions caused by fluctuations in the input power supply and to protect against external surge voltages. (*2) The XC8115/XC8116 series does not require an output capacitor (CL) for normal operation. However, it is recommended to connect a ceramic capacitor of 0.01 µF or greater as close to VOUT pin as possible to suppress output voltage fluctuations caused by load transient responses and to protect against external surge voltages. 6/27 Document Outline ■ GENERAL DESCRIPTION ■ APPLICATIONS ■ FEATURES ■ TYPICAL APPLICATION CIRCUIT ■ BLOCK DIAGRAM ■ PRODUCT CLASSIFICATION ■ PIN CONFIGURATION ■ PIN ASSIGNMENT ■ PIN FUNCTIONS ASSIGNMENT ■ ABSOLUTE MAXIMUM RATINGS ■ Recommended Operating Conditions ■ ELECTRICAL CHARACTERISTICS ■ ELECTRICAL CHARACTERISTICS ■ ELECTRICAL CHARACTERISTICS ■ ELECTRICAL CHARACTERISTICS ■ TEST CIRCUITS ■ OPERATIONAL EXPLANATION ■ Application Circuit Examples <Power Multiplexer> ■ OPERATIONAL EXPLNATION ■ OPERATIONAL EXPLNATION <Enable function> ■ OPERATIONAL EXPLANATION <Startup Mode / Soft-Start> ■ OPERATIONAL EXPLANATION ■ OPERATIONAL EXPLANATION < Thermal shutdown > < Short-Circuit Protection > ■ OPERATIONAL EXPLANATION < CL Discharge Function > * XC8115 series only < Reverse current protection function > ■ NOTES ON USE ■ TYPICAL PERFORMANCE CHARACTERISTICS ■ TYPICAL PERFORMANCE CHARACTERISTICS ■ TYPICAL PERFORMANCE CHARACTERISTICS ■ TYPICAL PERFORMANCE CHARACTERISTICS ■ TYPICAL PERFORMANCE CHARACTERISTICS ■ PACKAGING INFORMATION ■ Marking
