Datasheet HCPL-2300 (Broadcom)
ManufacturerBroadcom
Description8 MBd Low Input Current Optocoupler
Pages / Page14 / 1 — HCPL-2300, HCPL-0300. Data Sheet. Lead (Pb) Free. RoHS 6 fully. …
File Format / SizePDF / 329 Kb
HCPL-2300, HCPL-0300. Data Sheet. Lead (Pb) Free. RoHS 6 fully. compliant. Description. Features. Functional Diagram. Applications. ANODE
Datasheet HCPL-2300 Broadcom
Data Sheet Lead (Pb) Free RoHS 6 fully compliant
RoHS 6 fully compliant options available; -xxxE denotes a lead-free product
Description Features
The HCPL-2300/HCPL-0300 optocoupler combines • Guaranteed low thresholds: I = 0.5 mA, V ≤ 1.5 V F F an 820 nm AlGaAs photon emitting diode with an • High speed: guaranteed 5 MBd over temperature integrated high gain photon detector. This combina-tion of Avago designed and manufactured semiconductor • Versatile: compatible with TTL, LSTTL and CMOS devices brings new high performance capabilities to • Efficient 820 nm AlGaAs LED designers of isolated logic and data communication cir- • Internal shield for guaranteed common mode cuits. rejection The new low current, high speed AlGaAs emitter manu- • Schottky clamped, open collector output with factured with a unique diffused junction, has the virtue optional integrated pull-up resistor of fast rise and fall times at low drive currents. Figure 6 il- • Static and dynamic performance guaranteed from lustrates the propaga tion delay vs. input current charac- -40°C to 85°C teristic. These unique characteristics enable this device to be used in an RS-232-C inter face with ground loop iso- • Safety approval lation and improved common mode rejection. As a line – UL recognized -3750 V rms for 1 minute receiver, the HCPL-2300/HCPL-0300 will operate over – CSA approved longer line lengths for a given data rate because of lower I and V specifications. – IEC/EN/DIN EN60747-5-5 approved with F F V = 630 V (Option 060) IORM peak
Functional Diagram Applications
• Ground loop elimination
NC 1 8 V
• Computer-peripheral interfaces
CC
• Level shifting • Microprocessor system interfaces
ANODE 2 7 RL
• Digital isolation for A/D, D/A conversion • RS-232-C interface
CATHODE 3 6 VOUT
• High speed, long distance isolated line receiver
NC 4 5 GND A 0.1 pF bypass capacitor must be connected between pins 5 and 8. CAUTION:
It is advised that normal static precautions be taken in handling and assembly of this component to prevent damage and/or degradation which may be induced by ESD.
