Datasheet HCPL-2300 (Broadcom) - 2
ManufacturerBroadcom
Description8 MBd Low Input Current Optocoupler
Pages / Page14 / 2 — Schematic. Ordering Information. Option. Part. RoHS. non RoHS. Surface. …
File Format / SizePDF / 329 Kb
Schematic. Ordering Information. Option. Part. RoHS. non RoHS. Surface. Gull. Tape & UL 5000 Vrms/. IEC/EN/DIN. Number. Compliant. Package
Schematic Ordering Information Option Part RoHS non RoHS Surface Gull Tape & UL 5000 Vrms/ IEC/EN/DIN Number Compliant Package
The output of the shielded inte grated detector circuit is
Schematic
an open collector Schottky clamped tran sistor. The shield, which shunts capacitively coupled common mode noise to ground, provides a guaranteed transient immunity specification of 100 V/µs. The output circuit includes an optional integrated 1000 Ω pull-up resistor for the open collector. This gives designers the flexibility to use the internal resistor for pull-up to five volt logic or to use an external resistor for connec tion to supply voltages up to 18 V (CMOS logic voltage). The Electrical and Switching Characteristics of the HCPL-2300/HCPL-0300 are guaranteed over a tempera- ture range of -40°C to 85°C. This enables the user to con- fidently design a circuit which will operate under a broad range of operating conditions.
HCPL-xxxx is UL Recognized with 3750 Vrms for 1 minute per UL1577 and are approved under CSA Component Ac- ceptance Notice #5, File CA 88324.
Option Part RoHS non RoHS Surface Gull Tape & UL 5000 Vrms/ IEC/EN/DIN Number Compliant Compliant Package Mount Wing Reel 1 Minute rating EN 60747-5-5 Quantity
-000E no option 50 per tube -300E #300 X X 50 per tube -500E #500 X X X 1000 per reel HCPL-2300 300 mil DIP-8 -060E #060 X 50 per tube -360E #360 X X X 50 per tube -560E #560 X X X X 1000 per reel -000E no option X 100 per tube HCPL-0300 SO-8 -500E #500 X X 1500 per reel To order, choose a part number from the part number column and combine with the desired option from the option column to form an order entry. Combination of Option 020 and Option 060 is not available. Example 1: HCPL-2300-560E to order product of 300 mil DIP Gull Wing Surface Mount package in Tape and Reel packaging with IEC/EN/DIN EN 60747-5-5 Safety Approval and RoHS compliant. Option datasheets are available. Contact your Avago sales representative or authorized distributor for information. Remarks: The notation ‘#XXX’ is used for existing products, while (new) products launched since July 15, 2001 and RoHS compliant will use ‘–XXXE.’ 2
