Datasheet IRFD9020 (Vishay) - 2
ManufacturerVishay
DescriptionP-Channel Power MOSFET
Pages / Page9 / 2 — IRFD9020. THERMAL RESISTANCE RATINGS. PARAMETER SYMBOL. TYP. MAX. UNIT. …
File Format / SizePDF / 266 Kb
IRFD9020. THERMAL RESISTANCE RATINGS. PARAMETER SYMBOL. TYP. MAX. UNIT. SPECIFICATIONS. TEST. CONDITIONS. MIN. Static. Dynamic
IRFD9020 THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP MAX UNIT SPECIFICATIONS TEST CONDITIONS MIN Static Dynamic
IRFD9020
THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. UNIT
Maximum Junction-to-Ambient RthJA - 120 °C/W
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-Source Breakdown Voltage VDS VGS = 0 V, ID = - 250 μA -60 - - V VDS Temperature Coefficient VDS/TJ Reference to 25 °C, ID = -1 mA - - 0.056 - V/°C Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = -1 μA -2.0 - -4.0 V Gate-Source Leakage IGSS VGS = 20 - - 100 nA VDS = -60 V, VGS = 0 V - - - 100 Zero Gate Voltage Drain Current IDSS μA VDS = -48 V, VGS = 0 V, TJ = 150 °C - - - 500 Drain-Source On-State Resistance RDS(on) VGS = -10 V ID = - 0.96 A b - - 0.28 Forward Transconductance gfs VDS = -25 V, ID = - 0.96 A b 1.3 - - S
Dynamic
Input Capacitance Ciss - 570 - VGS = 0 V, Output Capacitance Coss VDS = -25 V, - 360 - pF f = 1.0 MHz, see fig. 5 Reverse Transfer Capacitance Crss - 65 - Total Gate Charge Qg - - 19 I Gate-Source Charge Qgs V D = - 11 A, VDS = -48 V, GS = -10 V - - 5.4 nC see fig. 6 and 13 b Gate-Drain Charge Qgd - - 11 Turn-On Delay Time td(on) - 13 - Rise Time tr V - 68 - DD = - 30 V, ID = -11 A, ns Rg = 18 , RD = 2.5, see fig. 10b Turn-Off Delay Time td(off) - 15 - Fall Time tf - 29 - Internal Drain Inductance L Between lead, D D - 4.0 - 6 mm (0.25") from nH package and center of G Internal Source Inductance LS die contact - 6.0 - S
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current I MOSFET symbol D S - - - 1.6 showing the  A integral reverse G Pulsed Diode Forward Current a ISM p - n junction diode S - - - 13 Body Diode Voltage VSD TJ = 25 °C, IS = -1.6 A, VGS = 0 V b - - - 6.3 V Body Diode Reverse Recovery Time trr - 100 200 ns TJ = 25 °C, IF = - 11A, di/dt = 100 A/μs b Body Diode Reverse Recovery Charge Qrr - 0.32 0.64 μC Forward Turn-On Time ton Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width  300 μs; duty cycle  2 %. S16-1506-Rev. D, 01-Aug-16
2
Document Number: 90170 For technical questions, contact: hvm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
