Datasheet TDS5B212MX (Toshiba)
ManufacturerToshiba
Description2 Differential Channel, 2:1 multiplexer/demultiplexer in XQFN16 package
Pages / Page14 / 1 — TDS5B212MX,TDS5C212MX. CMOS. Digital. Integrated. Circuits. Silicon. …
File Format / SizePDF / 564 Kb
TDS5B212MX,TDS5C212MX. CMOS. Digital. Integrated. Circuits. Silicon. Monolithic. TDS5B212MX,TDS5C212MX. 1. Functional. Description. •. 1-64GT/s
Datasheet TDS5B212MX Toshiba
TDS5B212MX,TDS5C212MX CMOS Digital Integrated Circuits Silicon Monolithic TDS5B212MX,TDS5C212MX 1. Functional Description • 1-64GT/s 1-Lane Two Differential Channel, 2:1 Mux/1:2 De-Mux 2. General TDS5B212MX, TDS5C212MX are high-speed differential channel multiplexer(Mux)/demultiplexer(De-mux) switches. These devices are designed to support up to 64GT/s high-speed differential interface such as PCIe® 6.0, CXL 3.x, USB4®Version 2.0, ThunderboltTM 5, DisplayPortTM 2.0. TDS5C212MX and TDS5B212MX have different pin layout.TDS5C212MX has an optimized pin assignment to achieve high frequency performance, while TDS5B212MX uses the same pin layout as conventional products. The A Port(An+/An-) is conneceted to either the B Port (Bn+/Bn-) or C Port (Cn+/Cn-), which is determined by the combination of both the select (SEL) and output enable pins (OE). When the output enable (OE) is held at a high-level, the switches are open (high-impedance state), regardless of the state of the select, thus these devices have lower consumption current. For device switch adjustment operations, Port A (An+, An-) has a weak differential resistance of 20 kΩ between the positive and negative terminals (An+, An-), and a weak pull-down resistance of approximately 1 MΩ from the An+ and An- terminals to GND. The devices are designed to operate in temperatures from -40 to 125 � and can be used for application including industrial use cases. 3. Features (1) Operating voltage: VCC = 1.6 to 3.6 V (2) Operating temputure: Tope = -40 to 125 � (3) Low current consumption, For active mode(Typ.) : Iope = 70µA (4) -3-dB Bandwidth (differential) BW(Diff) (Typ.) : TDS5C212MX = 34 GHz TDS5B212MX = 29 GHz (5) Differential insertion Loss DDIL (Typ.) : TDS5C212MX = -1.2 dB @ f = 16 GHz TDS5B212MX = -1.2 dB @ f = 16 GHz (6) Differential return Loss DDRL (Typ.) : TDS5C212MX = -14 dB @ f = 16 GHz TDS5B212MX = -15 dB @ f = 16 GHz (7) Differential Off Isolation DDOIRR (Typ.) : TDS5C212MX = -24 dB @ f = 16 GHz TDS5B212MX = -27 dB @ f = 16 GHz (8) Differential Crosstalk DDXT (Typ.) : TDS5C212MX = -31 dB @ f = 16 GHz TDS5B212MX = -31 dB @ f = 16 GHz (9) Package: XQFN16 4. Interfaces �PCIe 6.0 (PAM4) / 5.0 / 4.0 �Thunderbolt 5 / 4 / 3 �USB 3.2 Gen 2/Gen 1 �CXL 3.x / 2.x / 1.x �DisplayPort 2.0 / 1.4 �USB4 Version 2.0 , Gen3/Gen2 (PAM3) �SAS 3.0 � PCIe® is a registered trademark of PCI-SIG. � USB4® is a registered trademark of USB Implementers Forum. � Thunderbolt is a trademark of Intel Corporation or its subsidiaries. � DisplayPortTM is a trademark owned by the Video Electronics Standards Association (VESA®) in the United States and other countries. � Other company names, products, and service names may be trademarks of their respective companies. Start of commercial production 2025-11 ©2026 1 Toshiba Electronic Devices & Storage Corporation 2026-04-21 Rev.1.0.A
