Datasheet DCL540C01A (Toshiba) - 5
| Manufacturer | Toshiba |
| Description | High Speed Quad Channel Digital Isolators |
| Pages / Page | 38 / 5 — 6. Functional Description. (1). DCL540C01A/ DCL540D01A. (2) |
| File Format / Size | PDF / 1.4 Mb |
DCL54xx01A
6. Functional Description (1) DCL540C01A/ DCL540D01A
INPUT OUTPUT VDD1 VDD2 COMMENTS (Vix) (VOx) L L Normal Operation PU H H PU OPEN Default mode Default DCL540C01A=L , DCL540D01A=H PD L or OPEN PU X PD Undetermined When VDD2 is unpowered, a channel output is undetermined. PD L or OPEN Don’t use, since a certain voltage will be output through the PD X H - internal ESD circuit. PU= Powered up (VDD≥2.25 V), PD= Powered down (VDD≤1.7 V), H= High level, L= Low level, X= Don’t care
(2) DCL540L01A/ DCL540H01A/ DCL541L01A/ DCL541H01A/ DCL542L01A/ DCL542H01A
OUTPUT INPUT OUTPUT VDD1 VDD2 ENABLE COMMENTS (V (V (EN Ix) Ox) X) L L Normal Operation H or OPEN H H PU PU Default mode OPEN Default DCL540L01A=L , DCL540H01A=H L X Z Output Disable mode Default mode H or OPEN Default DCL540L01A=L , DCL540H01A=H PU L or OPEN PD L Z Output Disable mode Don’t use, since a certain voltage will be X X H - output through the internal ESD circuit. PU X When V L or OPEN Undetermined DD2 is unpowered, a channel output is undetermined. PD PD L or OPEN Don’t use, since a certain voltage will be X H X - output through the internal ESD circuit. PU= Powered up (VDD≥2.25 V), PD= Powered down (VDD≤1.7 V), H= High level, L= Low level, X= Don’t care 5 2026-07-14 ©2026 Toshiba Electronic Devices & Storage Corporation Rev.1.4
