Datasheet HLW8032 (Hiliwi Technology) - 7
ManufacturerHiliwi Technology
DescriptionSingle-phase metering IC in SOP8 package
Pages / Page18 / 7 — HLW8032. Technical specification. Typical. Parameter. Sign. Minima. …
HLW8032. Technical specification. Typical. Parameter. Sign. Minima. Maxima Unit. value. Precision. Analog input (all channels)
HLW8032 Technical specification Typical Parameter Sign Minima Maxima Unit value Precision Analog input (all channels)
Recommended working conditions
Positive power VDD 4.5 5.0 5.5 V Temperature range TA -40 - +85 ℃ Analog characteristics Unless otherwise specified, VDD= 5.0V,GND= 0V, on-chip reference voltage, on-chip oscillator, TMIN to TMAX = -40℃ to 85℃
Typical Parameter
符号
Active power Full gain range Input range 0.1% ~ PActive - ±0.2 - % 100% Current effective value Full gain range Input range 0.2% ~ IRMS - ±0.5 - % 100% Voltage effective value Full gain range Input range 0.2% ~ VRMS - ±0.5 - % 100%
Common mode signal -1 - 1 V
Analog input
Crosstalk interference in voltage channel - -100 - dB in the case of full range (50, 60Hz) Input capacitance IC - 6.4 - pF Equivalent input impedance 500 kΩ Current channel EII - 6 MΩ Voltage channel REV 1.5 7/16 www.hiliwi.com
