Datasheet RM07D471KC1IE100 (Dersonic) - 3
ManufacturerDersonic
DescriptionVaristors
Pages / Page16 / 3 — 編號DOC. NO.:. DEC-SA-WI007. 版本REV.:. B/1. 壓敏電阻器規格承認書. 日期DATE:. 2021/6/17. …
編號DOC. NO.:. DEC-SA-WI007. 版本REV.:. B/1. 壓敏電阻器規格承認書. 日期DATE:. 2021/6/17. APPROVAL. SPECIFICATION. FOR. VARISTORS. 頁碼PAGE:. 2. /. 15. 1. 規格表. DATA. SHEET. 本體顏色:
編號DOC NO.: DEC-SA-WI007 版本REV.: B/1 壓敏電阻器規格承認書 日期DATE: 2021/6/17 APPROVAL SPECIFICATION FOR VARISTORS 頁碼PAGE: 2 / 15 1 規格表 DATA SHEET 本體顏色:
編號DOC NO.: DEC-SA-WI007 版本REV.: B/1 壓敏電阻器規格承認書 日期DATE: 2021/6/17 APPROVAL SPECIFICATION FOR VARISTORS 頁碼PAGE: 2 / 15 1. 規格表 DATA SHEET 本體顏色: 蓝色 Body color: Blue 包封層: 环氧樹脂(UL94 V-0) Coating: Epoxy resin (UL94 V-0) 導線: CP線 Lead wire: CP wire 印字: ZNR Marking: 07D471K **D 產品編碼 RM07D471KC1IE100 Part number 客戶料號 C2761647 Customer P/N 最大連續工作電壓 AC300V (max) Max continuous operating voltage DC385V (max) 壓敏電壓, VN 470V±10% @ 1mA 30ms Varistor voltage, VN 標稱脈衝電流, Ip 10A @ 8/20μs Nominal pulse current, Ip 最大抑制電壓, VC 775V (max) @ Ip Maximum clamping voltage, VC 最大脈衝電流 1250A (1 time) @ 8/20μs Maximum pulse current 600A (2 times) @ 8/20μs (5 minute interval) 耐衝擊電流 重複脈衝電流 Withstanding 450A (10 times), @ 8/20μs (90 sec. interval) Repetitive pulse current surge current 衝擊壽命 75A (10 000 times) @ 8/20μs (10 sec. interval) Impulse life 最大耐受能量 29J @ 10/1000μs Maximum energy 額定功率 0.25W Rated power 最大漏電流 20μA @ 75% V Maximum leakage current N 最大電容量 105pF @ 1kHz 1.0Vrms Maximum capacitance 工作溫度範圍 -40ºC~+85ºC Operating temperature range D (Diameter) 9.5mm max T (Thickness) 3.8mm±0.8mm H (Heitht) 12.5mm max 尺寸 F (Lead spacing) 5.08mm±1.0mm Dimensions F1 (Lead malposed spacing) 2.51mm±0.5mm L (Lead length) 24mm±4.0mm ød (Lead diameter) 0.58mm±0.10mm
