Datasheet RM07D471KC1IE100 (Dersonic) - 8
ManufacturerDersonic
DescriptionVaristors
Pages / Page16 / 8 — 1μA. 10μA. 0.1mA. 1mA. 10mA. 0.1A. 1A. 10A. 100A. 1kA. 10kA. Current. …
1μA. 10μA. 0.1mA. 1mA. 10mA. 0.1A. 1A. 10A. 100A. 1kA. 10kA. Current. 編號DOC. NO.:. DEC-SA-WI007. 版本REV.:. B/1. 壓敏電阻器規格承認書. 日期DATE:. 2021/6/17. APPROVAL
1μA 10μA 0.1mA 1mA 10mA 0.1A 1A 10A 100A 1kA 10kA Current 編號DOC NO.: DEC-SA-WI007 版本REV.: B/1 壓敏電阻器規格承認書 日期DATE: 2021/6/17 APPROVAL
1μA 10μA 0.1mA 1mA 10mA 0.1A 1A 10A 100A 1kA 10kA Current 編號DOC NO.: DEC-SA-WI007 版本REV.: B/1 壓敏電阻器規格承認書 日期DATE: 2021/6/17 APPROVAL SPECIFICATION FOR VARISTORS 頁碼PAGE: 7 / 15 ■ 工作溫度降額曲線(見下圖) Operating temperature derating curve (see fig below) 请注意:額定特性包括最大連續工作電壓、耐衝擊電流、能量耐量及額定功率,降幅2.5%/ºC Please note: rated characteristic includes maximum continuous operating voltage, withstanding surge current, maximum energy and rated dissipation power, 2.5%/ºC reduction. ■ 壓敏電壓溫度係數 0 to -0.05 %/ºC max. Temperature coefficient of varistor voltage: ■ 儲存溫度範圍 -55ºC~+125ºC Storage temperature range: ■ 絕緣電壓 2500V 60s (body Insulation) Insulation voltage: 5. 名詞解釋 DEFINITIONS 1) 最大連續工作電壓:在环境溫度25ºC下,允許連續施加在壓敏電阻器上的最大工頻正弦電壓有效值Uac(總 諧波失真小於5%)或直流電壓值Udc。 Maximum continuous operating voltage: maximum ac RMS voltage Uac or maximum dc voltage Udc which can be applied continuously at a temperature of 25ºC. Uac shall be a substantially sinusoidal voltage (less than 5% total harmonic distortion). 2) 壓敏電壓:直流參考電流流過壓敏電阻器时,壓敏電阻器兩端的直流電壓值。 Varistor voltage: dc voltage across the varistor when the dc reference current flows through the varistor. 3) 標稱脈衝電流:是一個電流峰值,它是以每分鐘2次的方式用8/20μs脈衝電流衝擊100次,壓敏電阻器可以 通過的電大峰值電流的1/10。 Nominal pulse current: it is a current peak value. It is pulsed 100 times with 8/20μs pulse current in 2 times per minute, and the varistor can pass 1/10 of the peak current. 4) 抑制電壓:是指在標准大氣條件下,壓敏電阻器中通過標稱脈衝電流时,其兩端呈現的電壓峰值。 Clamping voltage: refers to the voltage peak appearing between the two terminals of a varistor when passing a nominal pulse current under standard atmospheric conditions. 5) 耐衝擊電流:壓敏電阻器允許通過的規定波形的每個脈衝的最大電流值。 Withstanding surge current: the maximum current value of each pulse of the specified waveform that the varistor is allowed to pass. 6) 能量耐量:能被壓敏電阻器吸收指定波形的最大單個脈衝能量,除非另有規定應使用10/1000μs脈衝。 Maximum energy: the maximum single pulse energy of the specified waveform that can be absorbed by the varistor. Unless otherwise specified, 10/1000μs pulses should be used. 7) 額定功耗:在25℃的环境溫度下的最大允許功耗。 Rated power: the maximum allowable power dissipation of varistors at an ambient temperature of 25ºC. 8) 漏電流:在25℃或規定的其他溫度下,施加最大直流電壓时,通過壓敏電阻器中的電流。 Leakage current: the current through the varistor at the maximum dc voltage applied at 25ºC or other specified temperature.
