Datasheet TCAN6062 (Texas Instruments) - 4
| Description | CAN XL transceiver with standby mode |
| Pages / Page | 44 / 4 — TCAN6062. www.ti.com. 4 Pin Configurations and Functions. Figure 4-1. … |
| File Format / Size | PDF / 1.6 Mb |
TCAN6062. www.ti.com. 4 Pin Configurations and Functions. Figure 4-1. SOIC (D) Package, 8 Pin
TCAN6062
SLVSM22 – JUNE 2026
www.ti.com 4 Pin Configurations and Functions
TXD 1 8 STB TXD 1 8 STB GND 2 7 CANH GND 2 7 CANH Thermal V 3 Pad CC 6 CANL V 3 CC 6 CANL RXD 4 5 NC,VIO RXD 4 5 NC,VIO Not to scale Not to scale
Figure 4-1. SOIC (D) Package, 8 Pin Figure 4-2. VSON (DRB) Package, 8 Pin (Top View) (Top View) Table 4-1. Pin Functions PINS TYPE DESCRITION NAME NO.
TXD 1 Digital Input CAN transmit data input GND 2 GND Ground connection VCC 3 Supply 5V supply voltage RXD 4 Digital Output CAN receive data output, tristate when powered off NC — Not internally connected; devices without VIO 5 VIO Supply Logic supply voltage; devices with VIO CANL 6 Bus IO Low-level CAN bus input/output line CANH 7 Bus IO High-level CAN bus input/output line STB 8 Digital Input Standby mode control input, integrated pull-up Thermal Pad Electrically connected to GND, connect the thermal pad to the printed circuit board (PCB) — (VSON only) ground plane for thermal relief 4 Submit Document Feedback Copyright © 2026 Texas Instruments Incorporated Product Folder Links: TCAN6062 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configurations and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 ESD Ratings, IEC Transients 5.4 Recommended Operating Conditions 5.5 Thermal Characteristics 5.6 Supply Characteristics 5.7 Dissipation Ratings 5.8 Electrical Characteristics 5.9 Switching Characteristics 5.10 Typical Characteristics 6 Parameter Measurement Information 7 Detailed Description 7.1 Overview 7.1.1 Signal Improvement Capability 7.1.2 CAN XL and FAST Mode 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Pin Description 7.3.1.1 TXD 7.3.1.2 GND 7.3.1.3 VCC 7.3.1.4 RXD 7.3.1.5 VIO (only for TCAN6062V) 7.3.1.6 CANH and CANL 7.3.1.7 STB (Standby) 7.3.2 CAN Bus States 7.3.3 Pulse-Width Modulation (PWM) for FAST Mode Signaling 7.3.3.1 PWM Detection and Timing 7.3.3.2 Transition from SIC Mode to FAST RX Mode 7.3.3.3 Transition from SIC Mode to FAST TX Mode 7.3.3.4 PWM Decoding 7.3.3.4.1 PWM Detection Resolution tDECODE 7.3.3.4.2 PWM Decoding in FAST RX Mode 7.3.3.4.3 PWM Decoding in FAST TX Mode 7.3.3.5 Transition from FAST RX/TX Modes to SIC Mode 7.3.4 Out-of-Bounds (OOB) Comparator 7.3.5 TXD Dominant Timeout (DTO) 7.3.6 CAN Bus short-circuit current limiting 7.3.7 Thermal Shutdown (TSD) 7.3.8 Undervoltage Lockout 7.3.9 Unpowered Device 7.3.10 Floating pins 7.4 Device Functional Modes 7.4.1 Operating Modes 7.4.2 Normal Mode 7.4.3 Standby Mode 7.4.3.1 Remote Wake Request via Wake-Up Pattern (WUP) in Standby Mode 7.4.4 Driver and Receiver Function 8 Application and Implementation 8.1 Typical Application 8.1.1 Design Requirements 8.1.1.1 CAN Termination 8.1.2 Detailed Design Procedures 8.1.2.1 Bus Loading, Length and Number of Nodes 8.2 System Examples 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Receiving Notification of Documentation Updates 9.2 Support Resources 9.3 Trademarks 9.4 Electrostatic Discharge Caution 9.5 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
