Datasheet TCAN6062 (Texas Instruments) - 9
ManufacturerTexas Instruments
DescriptionCAN XL transceiver with standby mode
Pages / Page44 / 9 — TCAN6062. www.ti.com. PARAMETER. TEST CONDITIONS. MIN. TYP. MAX UNIT. …
TCAN6062. www.ti.com. PARAMETER. TEST CONDITIONS. MIN. TYP. MAX UNIT. Driver - FAST TX mode. Receiver - SIC and Standby mode
TCAN6062 www.ti.com PARAMETER TEST CONDITIONS MIN TYP MAX UNIT Driver - FAST TX mode Receiver - SIC and Standby mode
TCAN6062 www.ti.com
SLVSM22 – JUNE 2026 parameters valid over recommended operating conditions with -40℃ ≤ TJ ≤ 150℃ (Typical values are at VCC = 5V, VIO = 3.3V, Device ambient maintained at 27℃ unless otherwise noted)
VCANH(INACT) CANH -0.1 0.1 V Bus output voltage standby TXD = STB = VIO VCANL(INACT) CANL -0.1 0.1 V mode RL = open, CL = open VDIFF(INACT) CANH - CANL -0.2 0.2 V V(CANH) = -15V to 40V, CANL = open, TXD = 0V or VIO or 250khz, 2.5Mhz square –115 115 mA Short-circuit bus output current,TXD is dominant wave IOS or recessive or toggling, SIC mode V(CAN_L) = -15V to 40V, CANH = open, TXD = 0V or VIO or 250khz, 2.5Mhz –115 115 mA square wave
TXD = Level_0 PWM symbol, STB = 0V VCAN_H0 Level_0 2.55 3.51 V Single ended voltage on 45Ω ≤ RL ≤ 60Ω, CL = open CANH TXD = Level_1 PWM symbol, STB = 0V VCAN_H1 Level_1 1.5 2.46 V 45Ω ≤ RL ≤ 60Ω, CL = open TXD = Level_0 PWM symbol, STB = 0V VCAN_L0 Level_0 1.5 2.46 V Single ended voltage on 45Ω ≤ RL ≤ 60Ω, CL = open CANL TXD = Level_1 PWM symbol, STB = 0V VCAN_L1 Level_1 2.55 3.51 V 45Ω ≤ RL ≤ 60Ω, CL = open TXD = Level_0 PWM symbol, STB = 0V VDIFF0 Level_0 0.6 1.5 V Differential output voltage 45Ω ≤ RL ≤ 60Ω, CL = open Fast TX mode TXD = Level_1 PWM symbol, STB = 0V VDIFF1 Level_1 -1.5 -0.6 V 45Ω ≤ RL ≤ 60Ω, CL = open TXD = PWM symbol of 5Mbps, 10Mbps, Driver symmetry in Fast TX mode 20Mbps, STB = 0V VSYM 0.95 1.05 V/V (VO(CANH) + VO(CANL))/(VCANH(R) + VCANL(R)) 45Ω ≤ RL ≤ 60Ω, CSPLIT = 4.7nF, CL = open V(CANH) = -15V to 40V, CANL = open, TXD =Level_0 PWM or Level_1 PWM 5Mbps, –115 115 mA Short-circuit bus output current,TXD is Level_0 10Mbps, 20Mbps IOS PWM or Level_1 PWM, Fast TX mode V(CAN_L) = -15V to 40V, CANH = open, TXD =Level_0 PWM or Level_1 PWM –115 115 mA 5Mbps, 10Mbps, 20Mbps
-12V ≤ VCM ≤ 12V, STB= 0V, RL = Open, VIT Input threshold voltage SIC mode CL = open 500 900 mV -12V ≤ VCM ≤ 12V, STB= VIO, RL = Open, VIT(STB) Input threshold voltage standby mode CL = open 400 1150 mV -12V ≤ V SIC mode dominant state differential input CM ≤ 12V, STB= 0V, RL = Open, VDIFF_RX(D) C 0.9 9 V voltage range L = open -12V ≤ V SIC mode recessive state differential input CM ≤ 12V, STB= 0V, RL = Open, VDIFF_RX(R) C -4 0.5 V voltage range L = open STB = V V IO, -12V ≤ VCM ≤ 12V, RL = Open, DIFF_RX(D_IN Standby mode dominant state differential input CL = open 1.15 9 V ACT) voltage range STB = V V IO, -12V ≤ VCM ≤ 12V, RL = Open, DIFF_RX(R_IN Standby mode recessive state differential input CL = open -4 0.4 V ACT) voltage range -12V ≤ V V CM ≤ 12V, STB= 0V, HYS Hysteresis voltage for input threshold SIC mode 100 mV Common mode range SIC, Fast and standby VCM –12 12 V modes ILKG(IOFF) Unpowered bus input leakage current CANH = CANL = 5V, VCC = VIO = GND 10 µA CI Input capacitance to ground (CANH or CANL) TXD = VIO 25 pF CID Differential input capacitance TXD = VIO 12.5 pF Copyright © 2026 Texas Instruments Incorporated Submit Document Feedback 9 Product Folder Links: TCAN6062 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configurations and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 ESD Ratings, IEC Transients 5.4 Recommended Operating Conditions 5.5 Thermal Characteristics 5.6 Supply Characteristics 5.7 Dissipation Ratings 5.8 Electrical Characteristics 5.9 Switching Characteristics 5.10 Typical Characteristics 6 Parameter Measurement Information 7 Detailed Description 7.1 Overview 7.1.1 Signal Improvement Capability 7.1.2 CAN XL and FAST Mode 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Pin Description 7.3.1.1 TXD 7.3.1.2 GND 7.3.1.3 VCC 7.3.1.4 RXD 7.3.1.5 VIO (only for TCAN6062V) 7.3.1.6 CANH and CANL 7.3.1.7 STB (Standby) 7.3.2 CAN Bus States 7.3.3 Pulse-Width Modulation (PWM) for FAST Mode Signaling 7.3.3.1 PWM Detection and Timing 7.3.3.2 Transition from SIC Mode to FAST RX Mode 7.3.3.3 Transition from SIC Mode to FAST TX Mode 7.3.3.4 PWM Decoding 7.3.3.4.1 PWM Detection Resolution tDECODE 7.3.3.4.2 PWM Decoding in FAST RX Mode 7.3.3.4.3 PWM Decoding in FAST TX Mode 7.3.3.5 Transition from FAST RX/TX Modes to SIC Mode 7.3.4 Out-of-Bounds (OOB) Comparator 7.3.5 TXD Dominant Timeout (DTO) 7.3.6 CAN Bus short-circuit current limiting 7.3.7 Thermal Shutdown (TSD) 7.3.8 Undervoltage Lockout 7.3.9 Unpowered Device 7.3.10 Floating pins 7.4 Device Functional Modes 7.4.1 Operating Modes 7.4.2 Normal Mode 7.4.3 Standby Mode 7.4.3.1 Remote Wake Request via Wake-Up Pattern (WUP) in Standby Mode 7.4.4 Driver and Receiver Function 8 Application and Implementation 8.1 Typical Application 8.1.1 Design Requirements 8.1.1.1 CAN Termination 8.1.2 Detailed Design Procedures 8.1.2.1 Bus Loading, Length and Number of Nodes 8.2 System Examples 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Receiving Notification of Documentation Updates 9.2 Support Resources 9.3 Trademarks 9.4 Electrostatic Discharge Caution 9.5 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
