Datasheet TCAN6062 (Texas Instruments) - 10
ManufacturerTexas Instruments
DescriptionCAN XL transceiver with standby mode
Pages / Page44 / 10 — TCAN6062. www.ti.com. PARAMETER. TEST CONDITIONS. MIN. TYP. MAX UNIT. …
TCAN6062. www.ti.com. PARAMETER. TEST CONDITIONS. MIN. TYP. MAX UNIT. Receiver - FAST RX mode. OOB Comparator
TCAN6062 www.ti.com PARAMETER TEST CONDITIONS MIN TYP MAX UNIT Receiver - FAST RX mode OOB Comparator
TCAN6062
SLVSM22 – JUNE 2026
www.ti.com
parameters valid over recommended operating conditions with -40℃ ≤ TJ ≤ 150℃ (Typical values are at VCC = 5V, VIO = 3.3V, Device ambient maintained at 27℃ unless otherwise noted)
RDIFF_PAS_RE Differential input resistance in passive recessive 12 100 kΩ C phase TXD = VIO, STB = 0V -12V ≤ VCM ≤ 12V, Single ended input resistance in passive Delta V/Delta I RSE_PAS_REC recessive phase 6 50 kΩ (CANH or CANL) Input resistance matching RIN(M) 2* [RIN(CANH) - RIN(CANL)] / [RIN(CANH) + RIN(CANL))] V(CAN_H) = V(CAN_L) = 5V –3 3 % × 100 %
-12V ≤ VCM ≤ 12V, STB= 0V, RL = Open, VIT(FAST) Input threshold voltage Fast RX CL = open -100 100 mV Fast mode Level_0 state differential input -12V ≤ VCM ≤ 12V, STB= 0V, RL = Open, VID(Level_0) voltage CL = open 0.1 9 V range Fast mode Level_1 state differential input -12V ≤ VCM ≤ 12V, STB= 0V, RL = Open, VID(Level_1) voltage CL = open -9 -0.1 V range
OOB Comparator
Input threshold voltage OOB comparator SIC VIT(OOB) -12V ≤ V mode CM ≤ 12V, STB = GND -450 -250 mV Low state differential input voltage range: OOB VID (OOB_Low) -12V ≤ V comparator SIC mode CM ≤ 12V, STB = GND -8 -0.45 V High state differential input voltage range: OOB VID (OOB_High) -12V ≤ V comparator SIC mode CM ≤ 12V, STB = GND -0.25 8 V
TXD Terminal (CAN Transmit Data Input)
V(TXD)THRESH TXD input threshold voltage Devices with VIO 0.95*(VIO/2) 1.05*(VIO/2) V V(TXD)LOW TXD input low voltage range Devices with VIO 0 0.95*(VIO/2) V V(TXD)HIGH TXD input high voltage range Devices with VIO 1.05*(VIO/2) VIO V R(TXD)PU Pull-up resistance on TXD input 20 80 kΩ R(TXD)PD Pull-down resistance on TXD input 20 80 kΩ 2 × (R Ohm/ m (TXD)PU − R(TXD)PD) / (R(TXD)PU + R(TXD) Pull-up and pull-down impedance matching -0.05 0.05 R(TXD)PD) Ohm IIH High-level input leakage current TXD = VIO = 5.5V; STB = 0V -1 1 µA IIL Low-level input leakage current TXD = 0V, VIO = 5.5V; STB = 0V -1 1 µA ILKG(OFF) Unpowered leakage current TXD = 5.5V, VCC = VIO = 0V –1 1 µA CI Input capacitance VIN = 0.4×sin(2×π×2×106×t) + 2.5V 5 pF
RXD Terminal (CAN Receive Data Output)
VOH High-level output voltage IO = –1.5mA, Devices with VIO 0.8VIO V Devices with V V IO OL Low-level output voltage 0.2V I IO V O = 1.5mA, Devices with VIO ILKG(OFF) Unpowered leakage current RXD = 5.5V, VCC = VIO = 0V –1 1 µA
STB Terminal (Standby Mode Input)
VIH High-level input voltage Devices with VIO 0.7VIO V VIL Low-level input voltage Devices with VIO 0.3VIO V IIH High-level input leakage current VCC = VIO = STB = 5.5V –2 2 µA IIL Low-level input leakage current VCC = VIO = 5.5V, STB = 0V –20 –2 µA ILKG(OFF) Unpowered leakage current STB = 5.5V, VCC= VIO = 0V –1 1 µA
5.9 Switching Characteristics
PARAMETER TEST CONDITIONS MIN TYP MAX UNIT Device Switching Characteristics
10 Submit Document Feedback Copyright © 2026 Texas Instruments Incorporated Product Folder Links: TCAN6062 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configurations and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 ESD Ratings, IEC Transients 5.4 Recommended Operating Conditions 5.5 Thermal Characteristics 5.6 Supply Characteristics 5.7 Dissipation Ratings 5.8 Electrical Characteristics 5.9 Switching Characteristics 5.10 Typical Characteristics 6 Parameter Measurement Information 7 Detailed Description 7.1 Overview 7.1.1 Signal Improvement Capability 7.1.2 CAN XL and FAST Mode 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Pin Description 7.3.1.1 TXD 7.3.1.2 GND 7.3.1.3 VCC 7.3.1.4 RXD 7.3.1.5 VIO (only for TCAN6062V) 7.3.1.6 CANH and CANL 7.3.1.7 STB (Standby) 7.3.2 CAN Bus States 7.3.3 Pulse-Width Modulation (PWM) for FAST Mode Signaling 7.3.3.1 PWM Detection and Timing 7.3.3.2 Transition from SIC Mode to FAST RX Mode 7.3.3.3 Transition from SIC Mode to FAST TX Mode 7.3.3.4 PWM Decoding 7.3.3.4.1 PWM Detection Resolution tDECODE 7.3.3.4.2 PWM Decoding in FAST RX Mode 7.3.3.4.3 PWM Decoding in FAST TX Mode 7.3.3.5 Transition from FAST RX/TX Modes to SIC Mode 7.3.4 Out-of-Bounds (OOB) Comparator 7.3.5 TXD Dominant Timeout (DTO) 7.3.6 CAN Bus short-circuit current limiting 7.3.7 Thermal Shutdown (TSD) 7.3.8 Undervoltage Lockout 7.3.9 Unpowered Device 7.3.10 Floating pins 7.4 Device Functional Modes 7.4.1 Operating Modes 7.4.2 Normal Mode 7.4.3 Standby Mode 7.4.3.1 Remote Wake Request via Wake-Up Pattern (WUP) in Standby Mode 7.4.4 Driver and Receiver Function 8 Application and Implementation 8.1 Typical Application 8.1.1 Design Requirements 8.1.1.1 CAN Termination 8.1.2 Detailed Design Procedures 8.1.2.1 Bus Loading, Length and Number of Nodes 8.2 System Examples 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Receiving Notification of Documentation Updates 9.2 Support Resources 9.3 Trademarks 9.4 Electrostatic Discharge Caution 9.5 Glossary 10 Revision History 11 Mechanical, Packaging, and Orderable Information
