Datasheet LR2012, LR2021, LR2022 (Semtech) - 4
ManufacturerSemtech
DescriptionLong Range, Low Power, Multi-band LoRa Transceiver​ in QFN32 5x5mm​ packages
Pages / Page250 / 4 — LR2021/LR2022/LR2012. Version. Date. Changes and/or Modifications …
File Format / SizePDF / 6.0 Mb
LR2021/LR2022/LR2012. Version. Date. Changes and/or Modifications (Continued). 4 of 250. Final Datasheet. Rev. 2.2. Semtech. DS.LR20xx
LR2021/LR2022/LR2012 Version Date Changes and/or Modifications (Continued) 4 of 250 Final Datasheet Rev 2.2 Semtech DS.LR20xx
link to page 250 link to page 235 link to page 210 link to page 51 link to page 163 link to page 217 link to page 136 link to page 67 link to page 137 link to page 137 link to page 137 link to page 137 link to page 137 link to page 137 link to page 80 link to page 155 link to page 240 link to page 117 link to page 182 link to page 237 link to page 219 link to page 209 link to page 226 link to page 51 link to page 53 link to page 53 link to page 209 link to page 211 link to page 234 link to page 211 link to page 214 link to page 157 link to page 143 link to page 144 link to page 145
Modified Expected degradation values in Table 23-1 2.1 April 2026 Modified footnote in Table 18-2 Added FLRC_260_CR05_915_S effective bit rate in Table 3-12 Removed 4-FSK from “PHY compatibility for protocols” on front page Added freq_offset to 9.9.9 GetLoraPacketStatus and 18.4.4 GetFlrcPacketStatus Added load pul specifications to Table 3-22 Modified 7.3.4 SetRssiCalibration Added Table 7-6: Recommended Values for Reference EVK HF path 2.4 GHz (loaded by default), Table 7-7: Recommended Values for Reference EVK LF path 868–915 MHz (loaded by default), and Table 7-8: Recommended Values for Reference EVK LF path 490 MHz (loaded by the application) Updated PA optimal values in Table 7-19, Table 7-20, Table 7-21 Added 5.3.3 Extending the Data FIFOs Removed “N 6.4 kbps” from 12.1 WM-BUS Modulation Modified 9.6 Fast CAD 2.2 July 2026 Modified 6.5.2 GetTemp Modified 23.4 Reference Design Modified Table 23-2: Register Usage Modified 19.3.1 SetOqpskParams Modified 20.3.4 GetZwavePacketStatus Added note to Table 3-12: FLRC Sub-GHz 1% PER (LR2021), Table 3-13: FLRC 2.4 GHz 1% PER (Packet Size = 31 bytes) (LR2021) Modified 18.1 FLRC Modulation, Table 18-3: Receiver Performance of the FLRC Modem, 18.1.3 Gaussian Filtering, 18.4.1 SetFlrcModulationParams, Modified link budget improvement value in 18.1 FLRC Modulation Added 22.4 Regulatory Compliance Modified LDRO activation criteria in 9.9.1 SetLoraModulationParams
LR2021/LR2022/LR2012 4 of 250 Final Datasheet Rev. 2.2 Semtech DS.LR20xx 29/07/26
www.semtech.com
Proprietary & Confidential
Document Outline 1. Chip Description 1.1 LR2021 1.2 LR2022 1.3 LR2012 1.4 Receiver RF Path 1.5 Transmitter RF Path 1.5.1 Low Frequency Power Amplifier (LF PA) (LR20xx) 1.5.2 High Frequency Power Amplifier (HF PA) (LR2021/22) 1.5.3 Direct-Tie Implementation (LR20xx) 1.6 Frequency Synthesizer 1.7 Modem 1.8 Power Distribution 1.8.1 Power-On Reset and Brown-Out Reset 1.8.2 Low Battery Detector 1.8.3 Over Current Protection 1.8.4 Power Supply Mode 1.9 Clock Sources 1.9.1 32 kHz RC Oscillator 1.9.2 32 MHz Crystal 1.9.3 32 MHz TCXO 1.9.4 External Clock Reference Inputs 1.9.5 Output Clock 2. Pin Connection 2.1 I/O Description 3. Specifications (LR20xx) 3.1 Absolute Maximum Ratings 3.2 Operating Range 3.3 ESD Protection and Latch-up 3.4 Electrical Specifications 3.4.1 Power Consumption 3.4.2 General Specifications 3.4.3 Receive Mode Specifications 3.4.4 Transmit Mode Specifications 3.5 Reference Oscillator Crystal Specification 3.6 SIMO Inductor Specification 3.7 Digital I/O and Interface Specifications 3.7.1 Digital I/O Specifications 3.7.2 SPI Interface Specifications 4. Chip Modes (LR20xx) 4.1 Chip Mode State Diagram 4.2 Reset 4.3 Start-up and Boot Calibration Sequence 4.4 Chip Modes 4.4.1 Sleep 4.4.2 Standby RC / XOSC 4.4.3 Frequency Synthesis (FS) 4.4.4 Receive (Rx) 4.4.5 Transmit (Tx) 5. Host Interface 5.1 Hardware Interface (LR20xx) 5.1.1 DIO Pins 5.1.2 SPI Interface 5.2 Busy Line Control (LR20xx) 5.3 Data FIFO (LR20xx) 5.3.1 Rx Data FIFO 5.3.2 Tx Data FIFO 5.3.3 Extending the Data FIFOs 5.4 Host-Command Interface (LR20xx) 5.4.1 Read Write Command 5.5 DIO Rx / Tx Triggers (LR20xx) 5.6 Host Commands Summary 5.6.1 Direct Radio FIFO Read/Write Commands (LR20xx) 5.6.2 Register / Memory Access Operations (LR20xx) 5.6.3 System Configuration / Status Operations (LR20xx) 5.6.4 Radio Configuration / Status Operations (LR20xx except FLRC Commands) 5.7 Host Interrupts (LR20xx) 6. Chip Control Commands (LR20xx) 6.1 Direct Radio FIFO Read/Write 6.1.1 ReadRadioRxFifo 6.1.2 WriteRadioTxFifo 6.2 Register / Memory Access Operations 6.2.1 WriteRegMem32 6.2.2 WriteRegMemMask32 6.2.3 ReadRegMem32 6.3 Chip Mode Control 6.3.1 SetSleep 6.3.2 SetStandby 6.3.3 SetFs 6.3.4 SetAdditionalRegToRetain 6.3.5 SetRx 6.3.6 SetTx 6.3.7 SetRxTxFallbackMode 6.3.8 SetRxDutyCycle 6.3.9 SetAutoRxTx 6.3.10 StopTimeoutOnPreamble 6.3.11 SetLoraCadParams 6.3.12 SetLoraCAD 6.3.13 SetCad 6.3.14 SetCadParams 6.3.15 SetCca 6.3.16 ResetRxStats 6.3.17 SetDefaultRxTxTimeout 6.3.18 SetRegMode 6.4 Chip Auto Calibration 6.4.1 Calibrate 6.4.2 CalibFE 6.5 Measurements 6.5.1 GetVbat 6.5.2 GetTemp 6.6 Low Battery Detector Configuration 6.6.1 SetLbdCfg 6.6.2 GetRandomNumber 6.7 Chip Status 6.7.1 GetStatus 6.7.2 GetVersion 6.7.3 ClearErrors 6.7.4 GetErrors 6.8 DIO Control 6.8.1 SetDioFunction 6.8.2 SetDioRfSwitchConfig 6.8.3 SetDioIrqConfig 6.9 Interrupt Control 6.9.1 ClearIrq 6.9.2 GetAndClearIrqStatus 6.10 Data FIFO 6.10.1 ConfigFifoIrq 6.10.2 GetFifoIrqFlags 6.10.3 ClearFifoIrqFlags 6.10.4 GetAndClearFifoIrqFlags 6.10.5 GetRxFifoLevel 6.10.6 GetTxFifoLevel 6.10.7 ClearRxFifo 6.10.8 ClearTxFifo 6.11 Clock Control 6.11.1 ConfigLfClock 6.11.2 ConfigClkOutputs 6.11.3 SetTcxoMode 6.11.4 SetXoscCpTrim 6.12 Temperature Compensation 6.12.1 SetTempCompCfg 6.12.2 SetNtcParams 7. Radio Frequency Front End Control 7.1 Overview (LR2021/LR2022) 7.2 Overview (LR2012) 7.3 RF Front End Commands (LR20xx) 7.3.1 SetRfFrequency 7.3.2 SetRxPath 7.3.3 GetRssiInst 7.3.4 SetRssiCalibration 7.3.5 ResetRxStats 7.3.6 SetTimestampSource 7.3.7 GetTimestampValue 7.3.8 GetCcaResult 7.3.9 SetAgcGainManual 7.3.10 GetRxPktLength 7.4 Power Amplifier Control Commands (LR20xx) 7.4.1 SetPaConfig 7.4.2 SelPa 7.4.3 SetTxParams 8. Modem Configuration (LR20xx) 8.1 Packet Type Selection 8.1.1 SetPacketType 8.1.2 GetPacketType 9. LoRa Modulation (LR20xx) 9.1 LoRa Modulation Principle 9.1.1 Spreading Factor (SF) 9.1.2 LoRa Bandwidth (BWLORA) 9.1.3 Coding Rate (CR) 9.1.4 Low Data Rate Optimization (LDRO) 9.1.5 LoRa Symbol Rate (Rs) 9.2 LoRa Packet Handler 9.2.1 Preamble 9.2.2 Header (explicit packets only) 9.2.3 Payload 9.3 Multi-SF Detection 9.4 Channel Activity Detection (CAD) 9.5 Multi-SF CAD 9.6 Fast CAD 9.7 Extended LoRa Rx Bandwidth 9.8 Intra-packet Frequency Hopping Compatibility with SX127x 9.9 LoRa Commands 9.9.1 SetLoraModulationParams 9.9.2 SF6 Compatibility with SX127x 9.9.3 SetLoraPacketParams 9.9.4 SetLoRaSynchTimeout 9.9.5 SetLoraSyncword 9.9.6 SetLoraSideDetConfig 9.9.7 SetLoraSideDetSyncword 9.9.8 GetLoraRxStats 9.9.9 GetLoraPacketStatus 9.9.10 SetLoraAddress 9.9.11 SetLoraHopping 9.9.12 SetLoraTxSync 9.9.13 SetLoraSideDetCad 10. RTToF (Round-Trip Time of Flight) (LR20xx) 10.1 RTToF Engine 10.2 RTToF Commands 10.2.1 SetRangingAddr 10.2.2 SetRangingReqAddr 10.2.3 GetRangingResult 10.2.4 GetRangingStats 10.2.5 SetRangingTxRxDelay 10.2.6 SetRangingParams 11. (G)FSK Modulation (LR20xx) 11.1 (G)FSK Modulation Principle 11.1.1 Modem Bandwidth and Bit Rates 11.1.2 (G)FSK Modulation Index 11.1.3 (G)FSK Limitations 11.2 (G)FSK Packet Handler 11.2.1 Fixed-Length Packet 11.2.2 Variable-Length Packet 11.3 (G)FSK Commands 11.3.1 SetFskModulationParams 11.3.2 SetFskPacketParams 11.3.3 SetFskWhiteningParams 11.3.4 SetFskCrcParams 11.3.5 SetFskSyncword 11.3.6 SetFskAddress 11.3.7 GetFskRxStats 11.3.8 GetFskPacketStatus 12. Wireless M-Bus (WM-BUS) (LR20xx) 12.1 WM-BUS Modulation 12.2 WM-BUS Packet Handler 12.3 WM-BUS Radio Commands 12.3.1 SetWmbusParams 12.3.2 GetWmbusRxStats 12.3.3 GetWmbusPacketStatus 12.3.4 SetWmbusFilteringAddress 13. Wi-SUN FSK (LR20xx) 13.1 Wi-SUN Modulation 13.2 Wi-SUN Packet Handler 13.3 Wi-SUN Radio Commands 13.3.1 SetWisunMode 13.3.2 SetWisunPacketParams 13.3.3 GetWisunRxStats 13.3.4 GetWisunPacketStatus 13.3.5 SetWisunPacketLen 14. Bluetooth Low Energy Physical Layer (LR2021/LR2022) 14.1 Bluetooth LE Modulation 14.2 Bluetooth LE Packet Handler 14.3 Bluetooth LE Radio Commands 14.3.1 SetBleModulationParams 14.3.2 SetBleChannelParams 14.3.3 SetBleTxPduLen 14.3.4 SetBleTx 14.3.5 GetBleRxStats 14.3.6 GetBlePacketStatus 15. BPSK Modem (LR20xx) 15.1 (D)BPSK Modulation 15.2 BPSK Radio Commands 15.2.1 SetBpskModulationParams 15.2.2 SetBpskPacketParams 16. OOK Modem (LR20xx) 16.1 OOK Modulation 16.2 OOK Packet Handler 16.3 OOK Commands 16.3.1 SetOokModulationParams 16.3.2 SetOokPacketParams 16.3.3 SetOokCrcParams 16.3.4 SetOokSyncword 16.3.5 SetOokAddress 16.3.6 GetOokRxStats 16.3.7 GetOokPacketStatus 16.3.8 SetOokDetector 16.3.9 SetOokwhiteningParams 17. LR-FHSS (LR20xx) 17.1 LR-FHSS Modulation 17.2 LR-FHSS Commands 17.2.1 LrFhssBuildFrame 17.2.2 LrFhssSetSyncword 17.2.3 ReadLrFhssHoppingTable 17.2.4 WriteLrFhssHoppingTable 18. FLRC Modem (LR2021) 18.1 FLRC Modulation 18.1.1 Modem Bandwidth and Bit Rates 18.1.2 FEC Coding Rate 18.1.3 Gaussian Filtering 18.1.4 FLRC Frequency Tolerance 18.2 FLRC Packet Handler 18.2.1 Fixed-Length Packet Format 18.2.2 Variable-length Packet Format 18.3 FLRC Time-on-Air 18.4 FLRC Radio Commands 18.4.1 SetFlrcModulationParams 18.4.2 SetFlrcPacketParams 18.4.3 GetFlrcRxStats 18.4.4 GetFlrcPacketStatus 18.4.5 SetFlrcSyncword 19. OQPSK_15_4 (LR2021) 19.1 OQPSK_15_4 Modulation 19.2 OQPSK_15_4 Packet Handler 19.3 OQPSK_15_4 Radio Commands 19.3.1 SetOqpskParams 19.3.2 GetOqpskRxStats 19.3.3 GetOqpskPacketStatus 19.3.4 SetOqpskPacketLen 19.3.5 SetOqpskAddress 20. Z-Wave (LR2021) 20.1 Z-Wave Modulation 20.2 Z-Wave Packet Handler 20.3 Z-Wave Radio Commands 20.3.1 SetZwaveParams 20.3.2 SetZwaveHomeIdFiltering 20.3.3 GetZwaveRxStats 20.3.4 GetZwavePacketStatus 20.3.5 SetZwaveBeamFiltering 20.3.6 SetZwaveScanConfig 20.3.7 SetZwaveScan 21. Test Commands (LR20xx) 21.1 Regulatory Overview 21.1.1 ETSI 21.1.2 FCC 21.2 SetTxTestMode 22. Known Limitations and Workarounds 22.1 OOK Detection Threshold Adjustment (LR20xx) 22.1.1 Description 22.1.2 Workaround 22.2 RTTOF Accuracy for SX1280-compatible Bandwidths (LR2021/LR2022) 22.3 Firmware Patch RAM (PRAM) 22.3.1 Loading the Patch RAM 22.3.2 Checking the Patch RAM 22.4 Regulatory Compliance 22.4.1 CN470 SRRC Compliance for China 22.4.2 IN865 Compliance for India 23. Application Information 23.1 Power Management 23.2 RF Shield Impact 23.3 Oscillator Recommendations 23.4 Reference Design 23.5 Unused Pins 23.6 Configurations via Register Change 23.7 OCP registers 23.8 Compatibility of Generation 1–4 LoRa Radios 24. Package Information 24.1 Package Outline Drawing 24.2 Package Marking 24.3 Land Pattern 24.4 Reflow Profiles 24.5 Thermal Information 24.6 Tape & Reel Information
